I have car A.D.D.
Will S-10 SBC headers fit our trucks?
As the title says. Will SBC headers for an s-10 fit in our trucks? I have a buddy who will give me a set if they will fit. But I would rather ask before tearing everything apart to find out. Does anybody know?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
At the body shop.
Re: Will S-10 SBC headers fit our trucks?
Id hazard a guess and say yeah. A S-10 frame is similar to a chevelle frame and they'll fit.
Come on gerald, you should know, with a torch and a welder, anything will fit
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
Old Heap Driver
Take a good look at the driver side header (S-10) and measure the clearance between the motor and steering shaft. On the S-10 the steering shaft runs through the header so the header is designed with clearance. That kick out might cause a problem on a C-10.
I have a V-8 S-10 but my C-10 is a big block so I can't really eyeball it for you.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
I have car A.D.D.
Thanks Bryan. That was the part I was afraid of is that steering shaft clearance. Would you mind taking a measure of your headers for me since they are on the S-10? That way it is more accurate than one of the header alone. That would be appreciated.
![]() Posted via Mobile Device
#6 | |
Old Heap Driver
Canadian Trucker
They fit, My truck has a set of s10 shortys on it right now. I'm not happy with them though (they came on the truck when I bought it), in order to pull some of the the spark plugs on the passanger side you have to remove the header, because of the way the pipes run.
#8 | |
Old Heap Driver
I have car A.D.D.
Awesome! Thank you for checking into all that for me Bryan. Dalaigh, thank you for that too. I will tell my buddy to hand em over. Thanks again.
