Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-01-2010, 11:57 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Winch Project
Well, I needed a winch and they are pretty pricey so I decided to build one with spare parts laying around. I built the majority last fall but now I am doing the wiring and polishing up the pull unit itself.
Here is a pic of the wiring so far. I had all these components laying around. The box is cast aluminum and is weatherproof with rubber gasket and stainless latches. It used to hold a temperature logger. This is nice becuase i plan on leaving it mounted on the trailer for loading vehicles and things. I wont have to worry about it getting wet. I included an ammeter to monitor the pull load and weatherproof covers on all switches.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-04-2010, 01:36 AM   #2
andyh1956
Re: Winch Project
clean fab. any chance of posting a diagram of how you wired those relays up? i have to do the same thing to my trailer & don't have relays. thanks!
andy
andyh1956 is offline   Reply With Quote
Old 12-14-2010, 10:45 PM   #3
Vintage Windmills
Vintage 4x4s
Re: Winch Project
Andy,
I don't have a wiring diagram but I'll post this better photo and try to explain it. The top two solenoids are for unspooling the winch. You can see the red terminal (positive) on the left one. The right one is negative. The bottom two solenoids are for pulling and are backwards from the top with positive on the right and negative on the left. The outputs of all solenoids are on the right side and this is where the motor will connect. The middle post (top) of the solenoids goes to my switch. The little box to the lower left is a circuit breaker. Thats pretty much the basics, hope this helps.
Second photo is of the switch and ammeter wiring. The positive from battery goes in series through ammeter and circuit breaker before going to solenoids. The top switch with only one wire is for a light I'm going to put on.
Third photo is of the holes I couterbored since I couldn't find the strain reliefs with enough thread for the thick walls on the box. This thing is going to be watertight.
Old 12-14-2010, 11:32 PM   #4
andyh1956
Re: Winch Project
ok got it! power in to the ammeter, through to the breaker, then through to sol #1, jumps to feed sol #2. the other two act as ground connects independent from each other. once i drew them out on a sheet of paper then i could trace the flow of electricity & make my motor run! thanks!
andy
Old 12-14-2010, 11:35 PM   #5
Allensracing
Allensracing's Avatar
Re: Winch Project
what solenoids did you use? I have heard that the starter relays cant handle the amperage
Allensracing is offline   Reply With Quote
Old 12-15-2010, 11:43 AM   #6
Vintage Windmills
Vintage 4x4s
Re: Winch Project
Andy,
I think I am going to first route power to the circuit breaker then to the ammeter. Its a little safer that way if there are any shorts.
Allen,
I just used standard solenoids that I had laying around. My winch is low current. Could be a concern if you have a large winch I suppose so check rating on what you buy vs. your winch. I'm sure you can find large enough ones to handle any winch. Think of the current it takes to crank a diesel.
Old 12-19-2010, 11:42 AM   #7
andyh1956
Re: Winch Project
solenoids for class eight diesel trucks should work fine, those starters pull 500 amps. the cab feed relays look just like the starter relays but are taller, prolly cause they stay on all the time. they would be the best to use. navistar (ih) part # for them is 1693495c91.
andy
