Old 01-10-2011, 06:07 PM   #1
orbot
orbot's Avatar
Anyone bought the LMC cargo lamp ?
For the mid 80's chevy cabs.. i bought mine and the mounting hardware for the lamp assembly is kind of weird, nothing like the original one...anyone else has bought this that can show me how the hell it goes..
orbot is offline   Reply With Quote
Old 01-10-2011, 06:28 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Anyone bought the LMC cargo lamp ?
If I had to guess (which I am) you drill a hole for that rubber plug to fit snugly then slide it in, Then install the screw threw the light base and into the threads in the rubber. As you snug the screw it swells the rubber for a tight weather proof seal, But don't over tighten it.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-10-2011, 06:35 PM   #3
Pop's C-10
Pop's C-10's Avatar
^That's how they work..i've used them before...I'd put some masking tap down, put tha light base up there, mark tha holes, center punch it, then drill out with a bit that matches, prime tha drilled holes, slip them in..
Pop's C-10 is offline   Reply With Quote
Old 01-10-2011, 06:35 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I got mine from LMC, the inserts you pictured would be for if your add'n the light. drill two holes that they will slide in snugly and when ya tight'n the screw they swell up and hold it tight.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-10-2011, 07:25 PM   #5
Melmann
Melmann's Avatar
I bought one of their lights and mine is like the one you have. I thought about using a newer model 3rd brake/ cargo light instead. Has anyone out there updated theirs? I don't mean to take your thread!
Mel
Melmann is offline   Reply With Quote
Old 01-10-2011, 07:27 PM   #6
orbot
orbot's Avatar
well i am replacing the old one..and thoose thing dont swell enough in order th remain in the stock holes... the lip goes inside the sheet metal right?? i think i will add a grommet and get it to work.. thanks guys.
Old 01-10-2011, 07:47 PM   #7
Pop's C-10
Pop's C-10's Avatar
no..tha lip is meant to stay on to outside of tha hole...they are called well nuts.
http://www.hansonrivet.com/w71.htm
