65 chevy truck sm318 to m20 swap
New guy here. Need some help if possible..
Just bought a 65 c10 shortbed with 292 and sm 318 Muncie 3-speed on the "tree"...it is the one with the warner overdrive tail shaft... Looking to swap a 350 with Muncie m-20. I know I got to change out the passenger motor mount to get the small block in there, so I got tut covered.. And I already purchased the m-20 trans so my heart is dead set on that.. I know the swap is pretty direct but haves few questions for anyone who may have "been there/done that"! 1. The truck is low tunnel. Will I have to modify the trans tunnel (except for cutting the shifter hole)? 2. Will the bellhousing, cross shaft, Shift fork & other linkage from the sm318 work with the Muncie m-20? 3. Can I run a bench seat without moving the engine forward? As I know the floor shift on a m20 will will be a few inches farther back. I will be running a hurst comp-plus shifter? I know this is a ton of $hit but I could really use any information that you all may have to offer to save me from wasting my time and money... Thank you in advance! Posted via Mobile Device |
Re: 65 chevy truck sm318 to m20 swap
Here's a pic for posterity!
![]() Posted via Mobile Device Posted via Mobile Device |
Im not shure about your question but what kind of grill is that, ive never seen one like that?
60-66 Nut
That would be a '63 grill. That's one of the many reasons the '63 is the favorite truck for some of us.
#5 | |||
60-66 Nut
I don't know if they still offer it, but Hurst used to have a bracket that raised the shifter body up higher than in a passenger car installation. Of course the shift rods are different as well. I found that particular shifter to work really well in these trucks. Of course that was with the high hump, so it may not be necessary for your truck. I can get you a pic if you like.
BAM!!!
Captain fab is the man! Thanks for all that.. I was most concerned with having to spend hours and hundreds of dollars on Ebay looking for clutch linkage parts...Putting it together, piece by piece... we all know how that goes... I am more relieved now knowing that all my $hit will can be re used with the M-20. Thank for the info about the 55-57 shifter as well. I already have a hurst Competition Plus shifter with shift linkage but if I get into a bind, I will keep that in mind.. A thousand thank you's and A big fat Merry Christmas ![]() |
