Old 04-27-2011, 07:06 PM   #1
djw32
Air bag bolt part number?
Hello,
Does anyone know the part number to this (see picture)?
djw32 is offline   Reply With Quote
Old 04-27-2011, 08:51 PM   #2
PGSigns
PGSigns's Avatar
Re: Air bag bolt part number?
I just measured what I needed and got mine from the local bolt supplier. They had the big washers but not the fancy aluminum one like in the picture. If memory serves me mine were 3/8 16 X 4 1/2 and I used a grade 8 bolt.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-27-2011, 11:29 PM   #3
djw32
Thanks.
I would really like to use what's in the picture. The washer and bolt in the picture looks like a clean install.
Old 04-27-2011, 11:47 PM   #4
slimneverdies
slimneverdies's Avatar
x2. I've been looking all over
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 04-28-2011, 08:30 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
The aluminum washer in MrShelley's pic is a custom piece. The bolt is as stated above. Look for SBC harmonic balancer washers- they are thick, hardened, and the right size...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-28-2011, 12:17 PM   #6
chapster
chapster's Avatar
If you have a machine shop in your area get them to machine a couple on the lathe.......
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 04-28-2011, 05:43 PM   #7
djw32
This is perfect! I totally forgot about the SBC harmonic balance washer. Would you recommend running only one washer per side?
Old 04-28-2011, 11:31 PM   #8
72MARIO
72MARIO's Avatar
I also used the harmonic balancer washer and 4" bolt. I think it should be oky. Would like to have a bigger bolt going into the bag though....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-29-2011, 12:50 AM   #9
SCOTI
SCOTI's Avatar
The same size bolts hold the front bags in place.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2011, 01:10 AM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
...Would like to have a bigger bolt going into the bag though....
You could drill for the other two holes and use short bolts through the upper flange of the arms. Would be overkill, but good for peace of mind...
-Chris
Old 04-29-2011, 03:15 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Aren't the bolt holes in the top and bottom of the bag in-line with each other?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 04-29-2011, 04:02 PM   #12
SCOTI
SCOTI's Avatar
Some are; some aren't.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2011, 07:43 PM   #13
72MARIO
72MARIO's Avatar
I know that the front bags are held in by two 3/8" bolts. The back "should" be oky I am slightly concerned with the bottom having only one 4' x 3/8" bolt. Probibly will never be a problem.
I think a plate could be made with room to bolt the two 3/8" bolts into the bags and have a 1/2" x 4" stud going through the trailing arm. Mabye over thinking it ?
I like how the post have ending....................................
2005 TAHOE DD
