Old 06-21-2011, 02:18 PM   #1
veinbar
veinbar's Avatar
Q-Jet Question
I am currently using a stock mechanical fuel pump that feeds my Q-Jet. There is no doubt in my mind that the stock mech fuel pump is delivering way too much fuel. I reek of raw gas every time I exit my truck. I know it's not my cam profile because it's stock. I have a regulator and PSI gauge to install, but I want it adjusted properly. I have the following application:
  • 350 bored .40 over
  • Stock "882" heads
  • Flat-top Pistons
  • Stock Cam
  • Longtube headers to 2.25" exhaust
  • Edelbrock Performer Aluminum Intake
  • Open Element Air Filter
What is the recommended fuel PSI that a Q-Jet should receive?
veinbar is offline   Reply With Quote
Old 06-21-2011, 02:35 PM   #2
jimbonice
jimbonice's Avatar
Re: Q-Jet Question
This isn't going to answer your question, but, there is no way a stock fuel pump is going to be supplying too much fuel for the q-jet. I would be looking at the carb as the possible problem as to why it is running so rich.
jimbonice is offline   Reply With Quote
Old 06-21-2011, 02:41 PM   #3
veinbar
veinbar's Avatar
Re: Q-Jet Question
If unregulated, a stock fuel pump can deliver too much fuel. The carb is a Sean Murphy Induction Stage two Q-Jet that has been rebuilt to match my exact application. I'm not saying that it can't be wrong, but it's the less likely culprate. I've heard many people suggest regulating the fuel before it arrives to the carb. I just want to know what that PSI sweet spot is for a QJet on a near stock application. I would rather run a little lean versus the plumes of fuel I deal with now.
Old 06-21-2011, 02:42 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Q-Jet Question
Not sure on a quadrajet, but a Rochester 2Jet (like a Pontiac Tripower) is 6 psi.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-21-2011, 03:32 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Re: Q-Jet Question
I believe all carbs need about 4-6 psi. It's very rare that a mechanical pump delivers too much fuel. Have you checked the float level? Could it be possible that they are stuck open?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-21-2011, 03:41 PM   #6
jimboh247
jimboh247's Avatar
Re: Q-Jet Question
SMI website says 4 psi.
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 06-21-2011, 07:54 PM   #7
jimbonice
jimbonice's Avatar
Re: Q-Jet Question
just to clarify, when you say stock mechanical fuel pump, is this a stock gm pump, or is it an aftermarket mechanical pump? Stock pumps weren't regulated from the factory that I know of.
Old 06-21-2011, 10:01 PM   #8
rayfinseats
Re: Q-Jet Question
6 sounds right to me. 4 sounds a little low. I would check the float level also.
rayfinseats is offline   Reply With Quote
Old 06-21-2011, 10:36 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Q-Jet Question
Haynes......for men lol says 5-9 psi
1/2 a pint or more in 15 secs
how high are you holding the pressure gauge?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-22-2011, 11:01 AM   #10
veinbar
veinbar's Avatar
Re: Q-Jet Question
It's a reman'ed oem mech fuel pump, not after market.
Old 06-22-2011, 11:04 AM   #11
veinbar
veinbar's Avatar
Re: Q-Jet Question
I will speak with Sean Murphy today and let you guys know what he says. It's looking like 4-6psi is the sweet spot. I will crack into the carb to check the float level, but only after speaking with SMI. This isn't something that they overlook or miscalculate often.
Old 06-29-2011, 12:00 PM   #12
veinbar
veinbar's Avatar
Re: Q-Jet Question
I forgot to post my findings on this matter. I did speak to one of Sean Murphy's techs yesterday, and he said that 4.5-5.5 psi is optimal for a 750cfm Q-Jet. Since my motor is close to stock, he suggested 5 psi. I'm adding a fuel pressure regulator soon, so I'll let you know what I find.
Old 06-29-2011, 03:00 PM   #13
tucsonjwt
Re: Q-Jet Question
Just a couple of WAGs (Wild A** Guess) on your fuel smell.
When I had a strong gas smell it was:
1) Fuel inlet nut not seated all the way. Fuel would seep out, high the hot intake manifold, vaporize, and show no signs of leaking.
2) My C20 has short vent tubes on the sending units, not lines to a vapor recovery canister under the hood. This was legal in 83 for 3/4 ton trucks (considered heavy duty trucks.) Those vent tubes are designed to release vapor right at the tank, which is right behind the cab (and driver's seat), so I got a good whiff of gas every time I exited the truck. My solution was to route long vent lines to the rear bumper and install vent caps on those lines back there. Now I get a big whiff of gas when I go back to the tailgate to load/unload the truck. Let me know if you want pics of this creative re-engineering.
tucsonjwt is offline   Reply With Quote
Old 06-30-2011, 09:12 PM   #14
raceman6135
Dino burner
raceman6135's Avatar
Re: Q-Jet Question
How much pressure is your fuel pump currently generating? I'm not sure I understand the logic of adding a regulator when the current pressure is unknown.
Quadrajets can stand a higher inlet fuel pressure than a Holley carburetor, so for performance applications, we generally run 7.5 to 8.0 PSI. However, if Mr. Murphy recommends you run 5.0 PSI on his carburetor, that's what you should run.
Keep us posted.
raceman6135 is offline   Reply With Quote
Old 06-30-2011, 09:43 PM   #15
rayfinseats
Re: Q-Jet Question
I had about 3 differenty fuel pressure gauges and pumps on a camaro and they always showed zero after warm up. Drove me crazy.
Old 07-01-2011, 12:37 AM   #16
jimbonice
jimbonice's Avatar
Re: Q-Jet Question
Let us know what you find out.
Old 07-01-2011, 04:11 AM   #17
lurch115
lurch115's Avatar
Re: Q-Jet Question
you are running a 750 cfm q-jet on a 350 with a stock cam?!?!?! fuel pressure isn't your problem. That carb. is WAY to big for the motor.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 07-05-2011, 12:38 AM   #18
raceman6135
Dino burner
Re: Q-Jet Question
The vast majority of Quadrajet carburetors are in the 750 to 850 CFM range, and they came stock on millions of small block Chevrolet engines. GM was able to use these carbs on a variety of engines because they are spreadbore carburetors, which means they have very small primary bores and very large secondary bores. Also, the secondaries open via a vacuum signal, so when set up properly, the secondaries do not open until the engine requires the extra airflow. Therefore, the 750 CFM Quadrajet isn't too large.
It remains to be seen, however, what the OP discovered was the fix to his problem.
