pitman arm cunundrums
well ive got one more question.... i swapd crossmember outa my 65 for that of a 85 ... im trying to use 85 steering linkage and retain manual box....
my question is will the 65 pitman arm work with the 85 linkage????? |
Re: pitman arm cunundrums
60-66 Nut
It should work. I've used the original draglink with the power steering box pitman arms.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I agree with the Captain. I have gone the other way and used later model pitman on ealy drag links, so you should be good to go.
thanx guys that answers my question... once i get this thing rollin ill post some pics in a build thread
But Found Her 25yrs Later!
This is the closest thread I could find related to my topic.
I will be using the old 66 manual steering box for awhile, but my pitman arm needs replacing: ![]() Do I need to buy one specific for the 60-66 trucks, or will the later models (73-87) work?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-27-2010 at 11:45 PM. |
Senior Enthusiast
Napa shows this part number for the 1966. The price could pay for a lot of power steering parts:
http://www.napaonline.com/Search/Det...+50014+2014024 For 1985 they show 4 different part numbers. This one looks the closest, but appears to have more of a drop. It is specified for manual steering. Perhaps you could take yours to the store and match them up to see exactly what’s different: http://www.napaonline.com/Search/Det...+50014+2014024 This one is also for manual steering: http://www.napaonline.com/Search/Det...+50014+2014024 Here are the other two for power steering: http://www.napaonline.com/Search/Det...+50014+2014024 http://www.napaonline.com/Search/Det...+50014+2014024 |
^Thanks
I found a good price through: http://www.thefind.com/search?query=...tby]=price_asc also ebay: http://cgi.ebay.com/ebaymotors/Pitma...item20b1a817b6 29.99 + 14 shipping = $43.99 Even at those prices; I'm thinking I might as well spend the difference and make the conversion to power steering. I have the pump and box from the suburban I bought for the motor. The problem is it is a 4x4, and its pitman arm won't work with a 2wd. I can get the whole Power Steering box and Pitman Pick-N-Pull for $60.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-28-2010 at 01:26 AM. |
Jonny
I may have something kicking around I can set you up with I'll take a look and pm you if I do.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
