Is it worth it
Okay on craigslist there is a 1980 Chevy 3/4 ton 4x4 (Federal Truck). Current Non-op. Locking front hubs, 4 speed with granny low, 350 motor, 410 gears.
$900 OBO do you think it is worth the price for axles, springs and trans and transfer case and other items to go into my blazer. I could probably put what I take out of mine in it to resale as a 1/2 ton 4x4 with auto I talked to the guy and he said it was driven there and someone stole the dizzy so I could probably make run for little of nothing here is the link http://visalia.craigslist.org/cto/2103297657.html
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
Junk Yartist
Re: Is it worth it
In my opinion, yes. Looking at the front end thought it doesnt look like an 80. 1980 had square headlights. it looks like a 79. It as a service body on it, so you could either sell or scrap the truck and make your money back. I would pull the spark plugs and see how they look. It will probably have a larger radiator than your blazer. In Cali that would be a plus.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
Windy Corner of a Dirty Street
Re: Is it worth it
I would say it is just for the parts alone. Offer them $500 take off the stuff you want then scrap the rest. In the end, your parts will probably only cost you $100-$200.
That truck could very well be a 1980. The lower level trucks still had round headlights in 1980.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Re: Is it worth it
I would say yes. Having a donor vehicle is much nicer than a pile of parts when you are doing a swap like that. You are going to a stronger drivetrain, getting rid of the 203 and getting lower axle gears all at once, plus you'll have all the things like cross members, clutch pedal and parts and drivelines there to use what you want.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
Re: Is it worth it
thanks for the replies I was thinking it would be worth it just wanted someone's thoughts on the idea the radiator shouldn't be any bigger because mine has a 400sb which has a big block radiator from the factory
