To Serp or not to Serp???
Alright lads,
I have been pondering this question and I am hearing varying reasons why it is beneficial to swap to a serpentine belt setup. Is it just for looks or are there performance benefits? I won't be running A/C, but I will have P/S and not alot of electrical mods. All comments accepted. I have an old school influence that says it's a complete waste of money and time. Is it? Cheers Irish
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
It's Better With Nitro
Re: To Serp or not to Serp???
If you were planning on running a lot of accessories, then it might be worth it, but for what it sounds like you are going to run, any benefits from a lower tension pulley system and stability for a long belt would not translate into one extra accessory...that you can run an extra belt to drive.
Even if you ran A/C, you can do what my buddy did on his '66... ![]() ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-07-2011 at 08:30 PM. Reason: added photos of belt system |
#3 | |
Here's what I currently have under the hood.
Resistance is Futile
If you are not going to run a bunch of stuff dont do it. You could convert to a long water pump and brackets if you have holes for them. If you want a/c, then I would consider it but you can still get Alan Grove or something if needed.
I put a serp set-up on my 'burb 454 and it is a maze of metric and ASE fasteners. I had to rebuild some parts and then align the pulleys after it was assembled. I would have started with a new kit or done old school brackets if I had known the can of worms I was opening. Hey, just my .02!!! ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#5 | |
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. Last edited by irish1966; 01-07-2011 at 09:09 PM. |
I have a serp set up from the late 80's or early 90's pickup and love it! if you have bolt holes in your cylinder heads it bolts right up, if no a/c you can pick up an ac delete bracket (about 20$) and run without ac and have the availability to add it later. Check with local junk yards, they usually let this stuff go with used motors so you might get a deal on one, it all bolts right on, only tedious part is pulling the p/s pulley and reinstalling it. Never sling a belt off again...
![]() Join Date: Sep 2006
The first picture is going in my 65. it is a BB though with all the whisle. The 2nd pic is of the 66. It has a partial serp since I had one from a parts truck I bought. it is just a fatter belt running the Alt. I don't have any power steering in it yet.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 01-07-2011 at 09:17 PM. |
#8 | |
One more ?.....
The SBC already has P/S. Will I be able to use the P/S pump from the 4.3 setup with the existing steering box?
my buddy bill sent me this pic. I guess this is the S-10 setup.
i guess this is the s-10 setup
1 bolt on the passenger head, with no load from an a/c compressor hould never be an issue. Power steering pump should be fine, maybe line issue? Make sure to get the bolts from him too, theyll help...
help!/ mtormite p/n is 34152 wow, $31.99 that's gone up in the last 5 years...
#15 |
Grandpa in the rustmobile...
I dont like the looks, unless you taking the whole truck on that style LS motor or something..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#16 | |
#17 | |
also says it is eligeble for free 2 day shipping too.. Last edited by pmkrew; 01-07-2011 at 10:49 PM. |
#18 |
I think before I put mine engine back into my truck I'm going to acid wash the brackets and then paint/ powder coat them black. It definitely is not the prettiest but it damn sure is economical and functional. Easy hook up for the late model alternator too!
#19 |
I lucked out on my power steering pump. It used the O-ring type fittings as opposed to a flared fitting. My steering box was 1980+ which matched the 1990 pump. If you get into a jam, I believe you can change the fitting on the pump to match your lines.
1980 was the year of change from flare to O-ring on the steering hoses.
#20 | |
#21 |
For sure. If i'm gonna do it, it will be at least cleaned up nice before going in. I have a 2nd small block that I may mock everything up on and get it right before putting it in.
#22 | |
#23 | |
#24 |
For a bit more money (once you add in all the hardware and belt ect of the serp system) you might consider this...
http://www.store.procompelectronics....oduct_id=36881 You can probably get it from Jegs or similar for less than the price shown from the mfg. Cool alternative. |
#25 |
The main benefit of a serpentine system is that it is able to run many accessories at a lower tension, which takes less horsepower to drive. Also, it is more stable for accessories that are mounted further away from the crank pulley. If you can make a late model system work, that would be great. As the others mentioned, be sure to grab all of the hardware and fasteners. Sounds like a great deal...and your idea of mocking it up on a spare engine is perfect. post some photos.
Here's a photo of my March system I cobbled together and modified to fit on my Pontiac...it was free, but it took a lot of effort and machining to work. ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
