Old 01-20-2011, 07:49 PM   #1
2badgn
HELP- 1984 GMC 3500- fuel leak from tank
I had a new fuel sending unit installed months ago by my local Chevy delaer. When I noticed after the unit was installed that the gauge was better but not 100% accurate, I brought the truck back to my dealer. Dont know what they did but now I have fuel leaking from the tank. THe truck was at the dealer for 2 weeks and the tank was full when I brought it there. It was near empty when I picked it up today. They fixed my horn by replacing the turn signal switch but now I have a fuel leak-- ARRRRRRR!!!!
I tried tightening the bolt on the side - but it kinda made it leak worse. By loosening the bolt a little, I got the leak down to a drop- Have a bucket under my truck now.
Didnt try tightening the other bolt bc I didnt know that it was also leaking but much less than the bolt on the side. Going to bring it back to the dealer. But in the meantime, do u think that its a washer or do I need a new fuel tank? Help please- Want to fix this ASAP.
Frank
2badgn is offline   Reply With Quote
Old 01-20-2011, 09:56 PM   #2
str8axle55
Re: HELP- 1984 GMC 3500- fuel leak from tank
I would say tank, unless the new sending unit is leaking and running down the tank. Can you see the sender between the cab and bed, does it look wet? The nuts/bolts an washers don`t go into the tank.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 01-22-2011, 09:18 AM   #3
dman1982
dman1982's Avatar
it could be the tank or the sending unit...i did this about same job on my truck when i got back from iraq, the tank started leaking so i pulled the tank and patched all the holes....if the dealership didnt replace the rubbing lines going into the sending unit it might just be the lines...they are kinda a pain in the a$$ to change out...at least for me anyhow.
dman1982 is offline   Reply With Quote
Old 01-22-2011, 12:38 PM   #4
codydubb
codydubb's Avatar
Looks about like one of my tanks did dripping from that same area. bad place for dirt and crap to get stuck between the tank and that plastic cover, rusted right through my tank.
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 01-22-2011, 12:59 PM   #5
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
rusted out tank...
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 01-23-2011, 10:27 PM   #6
Gregs71
Not sure if you are aware, but that plastic is just a shield to protect from debris. Unbolt those bolts (they only hold the plastic cover on) and take a look at your gas tank (which is secured by large steel straps-which are kinda difficult to remove).
If the fuel is leaking from the bottom of the metal tank you have a hole, if its leaking from somewhere on top of the tank it could be a fuel line, or gasket.
When I removed my plastic shield I could see a small pinhole where the fuel was leaking from-in fact the whole corner of my tank was swiss cheese...
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 01-23-2011, 10:54 PM   #7
texastruckjunky
texastruckjunky's Avatar
I had the same problem, but mine had a little pebble wedged between the plastic shield and the tank that rubbed a small hole in the tank. So i replaced the tank and left the plastic off. Problem solved.
texastruckjunky is offline   Reply With Quote
