Old 01-29-2011, 06:15 PM   #1
jbclassix
Junk Yartist
jbclassix's Avatar
more hub help!!!
I have a 91 3/4 ton 10 bolt that came factory with auto hubs. I recently upgraded to manual hubs. 2 weeks ago I destroyed my left front wheel bearings. I have replaced the spindle, hub and bearings (including the axleshaft bearing) and the hub. When I put the hub on, I had the same problem when I swapped to manual hubs. I installed the washer and snap ring on the inside of the axle shaft (as shown). I cannot get the hub to set in far enough to get the outer snap ring in the groove! I removed the snap ring, left the washer, and now the hub sits far enough in. I put the snap ring on the outside of the hub (second picture). This is the same way I did it when I switched to manual hubs. I did not have this problem on the right side. Am I doing something wrong?!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
