Old 02-05-2011, 10:22 PM   #1
Indy72
350 hydraulic lifter adjustment
What is the best way to adjust hydraulic lifters?
Indy72 is offline   Reply With Quote
Old 02-06-2011, 12:11 AM   #2
DT1
DT1's Avatar
Re: 350 hydraulic lifter adjustment
Warm engine. Remove valve covers. Adjust while idling. Back off until you hear slight clacking. Tighten until clacking just quits and go 1/2 turn more.
DT1 is offline   Reply With Quote
Old 02-06-2011, 09:34 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
If you have the intake off I like this method.
http://www.mountainperformanceonline...MadeSimple.pdf
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-06-2011, 12:33 PM   #4
Ticker
Everything you need to know is right here.
http://67-72chevytrucks.com/vboard/s...d.php?t=418725
There's no reason at all to adjust valves with the engine running...
Ticker is offline   Reply With Quote
Old 02-07-2011, 04:33 PM   #5
Indy72
I failed to mention that this is a rebuild with all new parts including lifters,pushrods,and rockers.
Old 02-07-2011, 10:11 PM   #6
Ticker
No worries; all of the methods I listed still work...and as noted, you really don't want to adjust them running.
