Old 02-14-2011, 06:29 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
DIY4x FGB52 kit question
Any of you guys that have used this kit on a 2wd to convert it to a 4wd, how did you locate the position for the rear spring hanger? Does one of the bolts go through the bottom of the front cab mount where the rivet was, or just in front of it?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-15-2011, 07:28 PM   #2
Firefighter
Re: DIY4x FGB52 kit question
Anybody???????
Yellville, Ar. USA
Old 02-15-2011, 07:47 PM   #3
leddzepp
Moderator
leddzepp's Avatar
moving to 4wd area...hopefully someone here has your answer.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-16-2011, 01:01 AM   #4
bikes&bowties
bikes&bowties's Avatar
I dint quite understand your question. I just measured from the front of the frame for the shackle eye hole.
bikes&bowties is offline   Reply With Quote
Old 02-16-2011, 04:53 AM   #5
woodwright
Enjoying left field
woodwright's Avatar
Have you called Kert at DIY4X? He's pretty helpful.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 02-16-2011, 08:38 AM   #6
duallyjams
duallyjams's Avatar
Yes the front cab mount needs to be trimmed.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-19-2011, 03:59 PM   #7
Firefighter
So one hole is actually lined up with the old rivet hole in the lower part of the front cab mount then? What about the front hanger does it just bolt on where the old mount was, or does it need to be relocated and holes drilled?
Yellville, Ar. USA
Old 02-19-2011, 06:15 PM   #8
duallyjams
duallyjams's Avatar
The front spring mount and the core support are welded as one so the core support stays in the same location.
James
IG duallyjams
Old 02-19-2011, 06:42 PM   #9
royo
royo's Avatar
Do this he can tell you
nickle and dime
royo is offline   Reply With Quote
