Old 05-03-2010, 02:21 PM   #1
red02chevy
Arrow Part number on 87 front & rear window rubber
Does anyone have the GM part numbers for the front and rear window rubbers for an 87? Or are they still even being made by GM? Thanks for any help.
red02chevy is offline   Reply With Quote
Old 05-03-2010, 03:44 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Part number on 87 front & rear window rubber
Front Gasket #471009 $160.37
Front Chrome Mldg #464471 $65.66
Front Black Mldg #466157 $24.16
Moulding cap is not available.
Gasket for rear slider is serviced on the sliding glass itself (according to my system) 78-83 years
Rear Slider Gasket #15593323 $91.39 84-91 years (is discontinued though)
Rear Fixed Glass Gasket with Mouldings #363110 $87.66 (is discontinued)
Rear Fixed Glass Gasket without Mouldings #15590421 $116.16
Rear Gasket Moulding with Slider #15589915 $114.30 (is discontinued)
Rear Gasket Moulding without Slider #464471 $65.66
Hope that helps.
RandyP is offline   Reply With Quote
Old 05-03-2010, 11:41 PM   #3
red02chevy
So I am guessing that the front would be:
What exactly is the rear fixed glass....gasket?? then the molding??? Are the black molding caps available?
Thanks for the help so far!
Edit: do you have the part number for the stock grille on an 87?
Old 05-04-2010, 07:44 AM   #4
RandyP
RandyP's Avatar
These trucks have two options for back glasses, solid glass or sliding glass, you did not specify which, so I gave you information on both. The front moulding cap is not available, the caps for the rear are available only for the solid glass, part #337837 $17.18 each.
For the grille, you have two options, with mounting holds and without mounting holes.
85 up, with mounting holes, #15554911 $169.05
85 up, without mounting holes, #15554910 $159.82
Old 05-04-2010, 08:28 AM   #5
red02chevy
Thats cool. Thanks again.
Rear Fixed Glass Gasket with Mouldings #363110 $87.66 (is discontinued) What color is the molding on this? Chrome or black?
Rear Gasket Moulding without Slider #464471 $65.66 Is this black or chrome?
Old 05-04-2010, 08:45 AM   #6
RandyP
RandyP's Avatar
It did not give color choices on the rear, I'm fairly certain all back glass mouldings were black though in that year.
Old 10-29-2014, 03:17 PM   #7
GM-1979
Hope that helps.
Hello Sir
Do you have # 15593323 rubber ?
Or do you know where can i find it please ?
GM-1979 is offline   Reply With Quote
