Old 03-04-2011, 03:16 PM   #1
jonesky2
jonesky2's Avatar
tbi swap help
im wanting to swap tbi to my 76 k10. it has a freshly rebuilt engine with a edelbrock performer intake and hooker headers.
im going to the junk yard to get everything. and im wondering what year should i look for and what will i need from the donor?
jonesky2 is offline   Reply With Quote
Old 03-04-2011, 04:04 PM   #2
Jonboy
Slots go on anything!
Re: tbi swap help
What kind of cam are you running? I would use a 4bbl to TBI adapter, so you can keep your intake. You will need a place to mount the CTS in the intake, Throttle Body and assorted sensors, a knock sensor (just buy one new, they are pretty inexpensive, and tend to self destruct upon removal), ECM, and wiring harness. I did this swap recently in my '74, and it was pretty easy. If you can score a tank and lines out of an '87 truck that would be ideal, but get the lines from a 87-91 Sub or Blazer can be made to work, too. You can always run an inline pump if you don't want to swap out the tank, but you will need to make sure you run a return line back to the tank.
I used a wiring harness from www.fuelinjectionconnection.com , and was very happy with it. I didn't want the hassle of 25 year old wiring for $245, so I figured it was a good tradeoff. If you do end up going that direction, you can get the TBI parts from any GM TBI vehicle, but try to get a 7747 ECM (87-93 truck).
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-05-2011, 01:06 AM   #3
jonesky2
jonesky2's Avatar
Re: tbi swap help
im going to buy a new cam when i do the swap. the person i bought the engine from put a new one in but he was going to put it into a carmaro. not sure which one to get
Old 03-05-2011, 01:18 AM   #4
jonesky2
jonesky2's Avatar
Re: tbi swap help
Part #2523-2042-N is this the wiring harness you used?
Old 03-05-2011, 07:25 AM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: tbi swap help
this is very long thread, but full of good info. all you questions should be answer'd in this .
http://67-72chevytrucks.com/vboard/s...d.php?t=317519
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-05-2011, 04:35 PM   #6
Jonboy
Re: tbi swap help
I'm not sure of the part #, I called Robert and got his recommendation. I would not go with too big of a cam when you re cam the engine. If it is too large, you may have to burn another chip.
