Old 03-05-2011, 07:49 PM   #1
BellyAche Jr.
How to Remove 1980 K10 Dashboard
How to Remove 1980 K10 Dashboard?
Seen mixed info on removal. Some say 4 bolts and pull it out and others post 4 bolts and it's spot welded in place. I need to rewire truck and want it out of the way for access. Ultimately, I have a 350 with Edelbrock fuel injection waiting to be dropped in, but I want new wiring as the previous owner cut and spliced like there was no tomorrow! Had '69 Chevelle and lost it to an electrical fire and don't want to relive the past. Thanks.
BellyAche Jr. is offline   Reply With Quote
Old 03-06-2011, 01:05 AM   #2
80SPORT
80SPORT's Avatar
Re: How to Remove 1980 K10 Dashboard
The metal part of the dash is welded in at the windshield ..i would not remove it unless it was damaged.
If you pull the dash pad gauges and glove box it is easy to replace the harness.
Just take notes where the donor truck harness is routed ...remember these truck were built on an assembly line so everything is designed to go in quickly.
Compared to a modern vehicle the wiring on our trucks is very simple.
80SPORT is offline   Reply With Quote
Old 03-06-2011, 01:16 AM   #3
BellyAche Jr.
Thanks, for the info. Don't need to make the project harder than it needs to be!
Old 03-06-2011, 01:20 AM   #4
grayharville
^^who I am^^ what I say>
grayharville's Avatar
To remove the dash pad you are gonna need a sawzall, cutting torch, and a hammer...
J/K all kidding aside there is somethin like 5 bolts holding the pad in, romove those, your gauge bezel, glovebox, maybe drop the steering column, and it should be enough room to rewire. good luck and welcome to the board
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 03-06-2011, 12:09 PM   #5
BellyAche Jr.
Thanks for the help. Glad you mentioned the sawzall. I was about to use some old M-80 firecrackers I had to loosen things up!
Old 03-06-2011, 07:56 PM   #6
grayharville
Yeah thats what I used on my last dashboard removal, a few m-80s and a mortar shell. hahaha
East Tx Squares
Old 03-06-2011, 10:00 PM   #7
BellyAche Jr.
Love it! You cannibalized a vette for a blazer!
Old 03-06-2011, 10:08 PM   #8
grayharville
To hell with that vette, the blazer is alot funner! its almost done... drivetrain is in it just needs wiring hooked up and accesorys put on
East Tx Squares
1980, dash, dashboard, dashpanel, k10
