62 Stock front shocks
Does anyone know length of the stock front shock fully extended and fully compressed?
Moderator
![]() ![]() Join Date: Aug 2011
Re: 62 Stock front shocks
I found a thread that lists a couple but doesn't have the measurement. But you can probably extrapolate the info.
http://67-72chevytrucks.com/vboard/s...d.php?t=165389
Are the 60-62's the same as the 63-66's that thread is talking about a 65
Take a measurement at ride height add at least 3" then -3" unless you're going long travel then Jack it up for full droop. If anyone has messed with torsion bars that just adds to fun
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
My truck has a 77 front clip with 2 inch drop coils so I can not do this to find out the stock spring height.
![]() Join Date: Mar 2006
RockAuto says:
Front: Shock Stroke 5.11 IN Body Diameter 41.40 Fully Open Length 14.64 IN Type Vintage Gas Charged Alternate/OEM Part Number(s): 88946138 Rear: Shock Stroke 10.61 IN Body Diameter 41.40 Fully Open Length 25.54 IN Type Vintage Gas Charged Alternate/OEM Part Number(s): 88946176 Length - stroke = collapsed length |
Awesome thanks. Should I then assume that fully compressed is 9.53”
Yes Sir,
14.64" expanded 9.53" compressed 5.11" stroke |
