Old 03-13-2011, 09:35 PM   #1
19seventeeCustom
Drop shock ??
Hey guys,
I'm in the process of lowering the truck with spindles and drop blocks. Well I'm still waiting on a few things so I haven't torn the truck apart yet, but have most of the parts sitting in the garage.
Right now my truck has only a spring drop, which I believe is a 2" or 3" inch drop spring in the front and a 4" in back. So I went ahead and ordered some drop shocks since I thought it would be a good time to replace the old shocks. I ordered the KYB shocks (same part # as ECE sells in their 4/6 drop kit). I put the new shock up in place and compared it to the current shocks and noticed at ride height the truck measures around 11" eye to eye. These KYB shocks I ordered bottom out at 10".......what gives??
Did I get the wrong shocks, does my truck have a lower than 3" drop spring?
If it matters the ground to middle wheel arch is 30" right now.
Should I look for a even shorter shock?
19seventeeCustom is offline   Reply With Quote
Old 03-14-2011, 10:15 AM   #2
19seventeeCustom
Re: Drop shock ??
any suggestions guys?
I also went to the monroe website and looked at some part #'s for shocks that guys usually use up front and the compressed length on those were 10 1/8", which would still be long.
I need some help!!
Old 03-14-2011, 11:15 AM   #3
SCOTI
SCOTI's Avatar
Re: Drop shock ??
Originally Posted by 19seventeeCustom View Post
Hey guys,
10" @ full compression sounds like a standard replacement front shock length (they vary between 10-10.5"L).
One solution would be to increase the dimension between the shock mounting positions. Up front, that means raising the upper mount. The other solution is to try contacting whomever your purchased the shocks from for an exchange.
I prefer to use off the shelf C10 spec'd units & move the mounts if possible.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-14-2011, 11:28 AM   #4
19seventeeCustom
Re: Drop shock ??
Thanks scoti,
How do you move the mount up, Is it as simple as removing the old mount and drilling a new hole for the lupper shock mount?
Old 03-14-2011, 12:00 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop shock ??
Here's some good info from this thread:
http://67-72chevytrucks.com/vboard/s...00#post4177700
Front Shocks
Doetsch Tech Shocks*
DT4809G 1960-62 front Doetsch Tech Shock stock height
DTM1200GLL 1960-62 front Doetsch Tech Shock lower height
DT4052G 1963-72 front Doetsch Tech Shock stock height
DT4809G 1963-72 front Doetsch Tech Shock 1"-2" lowered
DTM1200GLL 1963-72 front Doetsch Tech Shock 3" lowered
KYB Shocks KYB
KYM1200G 1960-62 front lowered KYB Shock, 2"
KY4809G 1960-62 front stock KYB Shock
KY4809G 1963-72 front lowered KYB Shock, 1"-2"
KYM1200G 1963-72 front lowered KYB Shock, 3"
KY4052G 1963-72 front stock KYB Shock*
Rear Shocks
KYB Shocks KYB
KY4163G 1963-72 w/ rear leaf stock or 1" - 2" drop
KY4095 1963-72 w/ rear leaf or 2" - 4" drop
KY4052G 1963-72 w/ rear leaf or 5" drop
KY4163G 1960-62 rear lowered*
KY4231G 1960-62 rear stock
KY4095 1963-72 rear lowered 2"-4"
KY4052G 1963-72 rear lowered 5-1/2"
KY4163G 1963-72 rear stock
Keith
Convert to disc brakes.
Old 03-14-2011, 12:04 PM   #6
19seventeeCustom
Re: Drop shock ??
Thanks alot Keith!
you guys are life-savers. I went ahead and cancelled my rear shock purchase because of it being backordered for weeks.
I think Im going to go ahead and just relocate the top shockmount, instead of sending these shocks back and having the hassle of paying shipping and returning.
Is it hard at all to relocate the top mount?
Old 03-14-2011, 12:06 PM   #7
lolife99
lolife99's Avatar
Re: Drop shock ??
Here's a set of front upper shock relocators from Performance Online.
http://www.performanceonline.com/196...-KIT-FSMK6372/
Keith
Old 03-14-2011, 12:11 PM   #8
lolife99
lolife99's Avatar
Re: Drop shock ??
I actually like the upper shock mount and shock from www.PorterbuiltStreetRods.com alot better.
These are the shocks and mounts shown with the Dropmember front crossmember,... but Nate sells them for stock crossmembers also.
Keith
