Old 03-28-2011, 06:29 PM   #1
Bulldog88
Sway bar question
Now that I mounted airbags and tubular a arms on a 97 1500 truck there is no place to mount the sway bar or shocks. Is the sway bar necessary? How are you guys mounting it?
Bulldog88 is offline   Reply With Quote
Old 03-28-2011, 06:30 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Sway bar question
What brand tubular a-arms do you have?
Most have mounts for a sway bar.
Keith
Convert to disc brakes.
Old 03-28-2011, 07:57 PM   #3
SCOTI
SCOTI's Avatar
Front sway bars are very desireable.... but not necessary. I install them on all of my builds.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-29-2011, 11:09 AM   #4
Bulldog88
I had someone build the a arms for me but I didnt notice that there wasnt a spot for the sway bar after installing them what can I do now? The purpose of the sway bar is to control roll or side to side movement right? Does the sway bar affect the lifting and lowering of the truck?
Old 03-29-2011, 11:52 AM   #5
SCOTI
SCOTI's Avatar
The sway bar helps limit torsional twist & thus helps keep the truck 'flatter' in corners/turns. They can affect lifting/lowering if they bind. Using links on the ends vs. solid mounted bushings helps alot. See Ride Techs swivel links to get a good idea vs. how they mount from the factory.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-29-2011, 12:00 PM   #6
cdowns
cdowns's Avatar
fabricate mounts
