Old 04-04-2011, 10:23 PM   #1
Psycho71
Psycho71's Avatar
What spline count do I have? (10bolt)
'85 K20 Burb 10bolt/14bolt SF.
Needing some front shafts for it, and was wondering if I could know which spline I needed w/o having to pull the shafts in it now.
Will swap them out, and then rebuild the old ones for spares. Just don't want the burb out of commission while I'm hunting up axles for it. And kinda need them quickly. Have a run I want to make next weekend. I know there are plenty out there, just a matter of knowing which spline I need and I could order a set tonight.
Thanks,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 04-05-2011, 06:16 AM   #2
Blazer1970
Blazer1970's Avatar
Re: What spline count do I have? (10bolt)
If original, they are 28 spline.
Blazer1970 is offline   Reply With Quote
