Old 04-15-2011, 11:19 AM   #1
Jobe72
Jobe72's Avatar
Oil pan removal question
I have a 1972 GMC Sierra 1/2 ton with stock 350/350.
I need to reseal the timing chain and oil pan, can the oil pan be removed with the engine in the truck? Looks like it's pretty tight fit between the front cross memeber at the oil pan. This is my faily driver right now so I don't want to get half way into the job and realize I'm screwed!
Going to replace the timing gears/chain and oil pump while I"m in there, who knows how old the ones in there are!
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 04-15-2011, 11:37 AM   #2
JORGIE95961
Re: Oil pan removal question
honestly it can but its easier to take it out ar at least lift it im my opinion... the option is to drop the front end
JORGIE95961 is offline   Reply With Quote
Old 04-15-2011, 11:42 AM   #3
txriverrat
You don't have to pull the motor. What I did was unbolt the motor mounts and jack the engine up a few inches, then insert 2x4 blocks between the mounts and frame to hold the engine up a few inches. More than enough room to get the job done, and lots quicker than pulling the whole thing out.
txriverrat is offline   Reply With Quote
Old 04-15-2011, 04:03 PM   #4
Jobe72
Jobe72's Avatar
Thanks, there is no way I'm going to pull it out. I do have a cherry picker I could lift it up with though.
Old 04-15-2011, 04:22 PM   #5
cdowns
cdowns's Avatar
that is the way it is recomended in the factory service manual
i've found it works better with using a 1/4 drive ratchet and especcially a long extension in the deep part of the pan
Old 04-15-2011, 07:45 PM   #6
lt704
I don't want to steal this thread, but i have to change my oil pan gasket to. I have a 350 engine in my 68 ( was a six cyl. ). This winter put new motor mounts in using a cherry picker, it was very tight. If i took out the distribitor and did the same above would that give me the room? Thanks...Russ
lt704 is offline   Reply With Quote
Old 04-15-2011, 08:06 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes but you might get away with just pulling the cap and rotor. It'd save you a lot of trouble not having to re-time it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-16-2011, 11:14 AM   #8
lt704
Once again thanks for helping with the information VetteVet.....Russ
Old 04-16-2011, 03:30 PM   #9
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I know this is the way to do this...BUT! where abouts are you guys putting the jack? crossmember is in the way, can't jack from the pan for obvious reasons, so all's left as far as I can tell is the bottom of the Harmonic Balancer.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-16-2011, 04:18 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Not using a jack from below... using a cherry picker from above.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
