Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-21-2011, 02:42 PM   #1
Top Banana
Top Banana's Avatar
WTB 73-74 inner grille supports
I want to buy a pair of inner grilles supports for the '73-'74 Chevrolet like these
http://www.topbananaparts.com
Top Banana is offline   Reply With Quote
Old 03-21-2011, 02:45 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: WTB 73-74 inner grille supports
You may know this already, but they are welded to the core support. If these are to retrofit a 73/74 grill to a 75-80, they aren't needed to be honest, the center support and outer supports do the job just fine.
bigblock73 is offline   Reply With Quote
Old 03-21-2011, 02:50 PM   #3
Top Banana
Top Banana's Avatar
Jeff,
I've got a set of bolt in here and I'm trying to figure out exactly what they go to. They look like the ones in the photo and fit the 73-74 grille so I'm baffled.
Old 03-21-2011, 04:37 PM   #4
bigblock73
yeller
bigblock73's Avatar
Haven't seen any bolt in ones. My 73 has them factory spot welded. Perhaps 74 is different and they were bolted??
Old 03-21-2011, 04:51 PM   #5
Top Banana
Top Banana's Avatar
I wonder if the service part later on started using them so they could service 73-80 with one core support. We just tried bolting these into a '77 and they fit in place of the '77 inner bracket but they aren't right for the grille holes (too far outboard). We also just looked at an untouched '73 and they were welded.
Has anyone used the generic aftermarket "73-80" radiator support?
Old 03-21-2011, 05:33 PM   #6
RandyP
Getting Old; Going Broke
RandyP's Avatar
I went out and looked at the two 73's and the one 74 I have, those are both "part of the support" on all 3. They are not a bolt on thing as mentioned.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-21-2011, 05:50 PM   #7
Top Banana
Top Banana's Avatar
agreed- the illustrated parts book does show bolt on supports for the 73-74 GMC. Does anyone have one apart by chance?
Old 03-21-2011, 11:34 PM   #8
HOTFUN
HOTFUN's Avatar
Yes GM used a service part for them for 73-74 grilles and I picked one up a while back and it showed in the engineering diagram to screw them on to the radiator support. I can't put my hands on it right now as its in another location. There were two brackets and and maybe hardware in that GM box.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is online now   Reply With Quote
Old 03-22-2011, 12:20 AM   #9
KrazyRay
KrazyRay's Avatar
I pulled those same bolt on brackets from a 74 Jimmy, yet the 73 Blazer and the 73 truck had the welded ones.
KrazyRay is offline   Reply With Quote
Old 03-22-2011, 02:17 AM   #10
jlmerie
jlmerie's Avatar
I have removed multiple sets of these and have never seen any that were welded on.
James
jlmerie is offline   Reply With Quote
Old 03-22-2011, 07:04 AM   #11
Top Banana
Top Banana's Avatar
there are definately bolt in ones which, I think, were used in service parts for all '73-'74 Chevrolets and all '73-'78 GMCs.
Old 03-22-2011, 08:23 AM   #12
glimmertwin01
glimmertwin01's Avatar
the grille screw holes on a chev and a gmc are different locations... further outboard on the 73 74 chevy than a 75// I tried using a 75-75 GMC set on my 77 jimmy... the recess was correct for them andf the center did work but the outer locations werent....
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 03-22-2011, 09:53 AM   #13
Top Banana
Top Banana's Avatar
correct- the 73-74 Chevy are closer to the center (horizontally) and also a couple inches closer together (vertically). According to the parts book back in 70's the 73-74 Chevy would also fit the GMC through '78. The '75 Chevy mounts are closer to the fenders and on the outside edges of the grille as opposed to being in the openings in the grille
Old 03-22-2011, 01:52 PM   #14
Top Banana
Top Banana's Avatar
bolt on supports for reference-
Old 03-22-2011, 01:54 PM   #15
Top Banana
Top Banana's Avatar
and another pic
Old 03-24-2011, 11:26 AM   #16
big10charlie
I have numerous sets of the bolt on ones that came from a 73 or 74 with the sunken grill!
big10charlie is offline   Reply With Quote
Old 03-24-2011, 09:00 PM   #17
KrazyRay
KrazyRay's Avatar
I found a set of those brackets. $27 shipped. I can post pics soon.
Thanks,
Ray
Old 03-25-2011, 12:04 PM   #18
KrazyRay
KrazyRay's Avatar
Here's a pic of the ones I pulled from a 74, but they look different than your pic. Maybe someone can chime in to verify.
Old 03-25-2011, 12:48 PM   #19
Top Banana
Top Banana's Avatar
that's bizzare....they don't look anything like the others.....LOL
Do you have a closer pic? Or could you e-mail a bigger picture to thetopbanana@topbananaparts.com ?
Old 03-25-2011, 11:08 PM   #20
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Those are 75+.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 03-26-2011, 12:01 AM   #21
KrazyRay
KrazyRay's Avatar
Originally Posted by 1BadSS View Post
Those are 75+.
Thanks. I receive a bunch of mix and match trucks. I guess this was one of them.
Old 03-28-2011, 05:13 PM   #22
big10charlie
are those for a van?
Old 04-06-2011, 03:50 PM   #23
Top Banana
Top Banana's Avatar
big10charlie - I could still use some of the bolt in ones. Let me know what you have.
There should be one more piece to go with the piece in the bottom of this picture
Old 04-08-2011, 11:10 AM   #24
big10charlie
I have the center piece as well! PM me!
Old 04-22-2011, 05:44 PM   #25
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I know this thread is a little old but...
I bought these brackets from him along with the center and outer brackets (thanks by the way) and didn't use these supports you are speaking of. I just used the center and outer brackets, and I feel it holds the grille good enough. They look just like the ones you have pictured in this post:
Originally Posted by Top Banana View Post
and another pic
Do you still want a set?
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
