Looking to learn about rear ends!
Hey guys,
I'm sure like alot of you guys I spend alot of time thinking about my truck, but it was winter when I bought it & up where I am that meant I didn't get much of a chance to thoroughly check it out, & I've learned so much more since I've last laid my eyes on her.. Right now its sitting at a transmission guys place about to be fixed up, theres something wrong inside the transmission & that is beyond my current knowledge so now I wait.. What I'm wanting to learn/discuss is this: how do I figure out what the gears are in my rear end? I've got an '87 Chev V10 LWB 4X4 with a 92 corvette tpi 355. The rear end is 10 bolt I believe (does that mean its posi!??), & when I looked on Chucks Chevy Truck Pages, everything is leading me to believe that I would have 3.08:1 ratio.. I'm running 33" tires & I'm considering going to 35" tires & I'm wondering if my rear end could handle 35s, so I'm also wondering, how do I know what rear end is best for specific tire sizes. I'm willing to swap axles & everything, over time, to get the most out of my baby ![]() Thanks for any help, I'm really just a youngan getting into squares & I have much much more to learn, but heres a pic of mine ![]() ![]() |
Moderator
![]() Join Date: Oct 2008
Re: Looking to learn about rear ends!
A good place to start is the service parts identification label in the glovebox or sometimes under the hood on the inner fender.
The Limited Slip diff will be RPO code "G80". The original axle ratio(s) might be listed. 3.08 would be GU4 |
One shot, one kill.
Heavy, nice truck, especially for a snow belt truck. OK, now for your question. Yes you can run 35's. How well is another issue. You'll have the power but there may be a durability\reliability issue. Everything you do is a balancing act and if you don't get close to right something is going to suffer someplace along the way. Bigger tires effectivly lowers the rear end ratio (EG, a 3.08 rear end may behave like a 2.73) Great for fuel ecomomy but performance will suffer and rear end gear loading increases. You could go to 3.73's or 4.10 but your fuel ecomomy will suffer. Next is finding the gear ratio. With our trucks you can never be sure exactly what's in them, so here are a few ways to check. Not real accurite but it'll get you close. Jack up the rear end. Leave 1 tire on the ground. (if the shaft won't turn it's posi so you'll have to jack the other tire and let it rotate 1 full turn without dividing by 20 Mark the floor and tire and mark the drive shaft at the rear pinion. SLOWLY rotate the drive shaft and count the turns until the tire has rotated EXACTLY half a turn, OR, if you let the tire go 1 full turn, divide the pinion rotation number by 2. Next is accurite IF no one has changed gears. On top of the right axel tube there are a series of numbers and letters. Record them and do a search to find the ratio. Last check is positive. Pop the rear end cover and rotate the ring gear until you see a series of numbers. Your looking for a set of numbers that look like this "00:00" those aren't the numbers you'll see, just an example of their arrangement. 15:41 = 2.73. Divide the big number (41) by the small number (15). The 41 is the number of teeth on the ring gear. 15 is the number of teeth on the pinion gear. With the rear open you'll be able to see if it's posi by looking at the guts inside the carrier (the caasting the ring gear is bolted to) if all you see is 4 gears and a cross shaft it's non posi (open rear) If there looks to be plates under the side gears or some gearing mounted to the carrier it's posi. Hope this helps, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Junior Member
Heavy... good looking little truck there. To run 35 / 36s the closest gear match to put you back in average hwy operating range would be 4:56. Especially if you are using a 700r.
78K & 79C Jimmys
very nice looking truck
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Junior Member
Here is my "big-ole-ugly-blue burb-winter-beater" ha ha ha ha ha ha
heavy, I dont know alot about rear end configuration, but dude your truck is a beaut. I would love to get my hands on a Four By one day.
Good 6 lug upgrades for the rear are the semi floating 14 bolt and the 12 bolt.
for the front, dana 44. If you dont mind going to 8 lug wheels, there is the full-floating 14 bolt rear and the dana 44 or 60 front axle. With 35s I would suggest at a minimum 4.10 gears with 4.56s being a more desireable way to go.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
great looking truck, i'd take cover off rear end just to be sure nothing has been changed gear wise, and i run 38.5s with 4.10s don't really have a problem but i don't use use 4th either and its through a stock tbi 350
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold 2003 1500 Silverado - Selling 2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LB SRW |
