Old 03-24-2003, 11:11 PM   #1
ocbaud
Garage Queen Material
6/8 drop this summer?
well, you guys remember the loud scraping sound i was complaining about before. well i found out what it was, it was the inner wheel bearing digging its way into the spindle! i had to break the bearing to get the wheel hub off, and that left the inside retainer to the bearing attached to the spindle. it was dug in good and deep over 1/2" i had to take my dremel to it to get it off the spindle. i'm suprised that they did check it out when it was in the shop, since my dad did say he was haveing them check out everything to make sure my truck was completely safe
so anyway, i replaced the bearing and its doing good and rides good, but the spindle will have to be replaced since it was messed up so bad, the hub still has a hard time getting off.
so i'm thinking that this summer when i replace the spindles, i will get some djm 3" spindles along with some new 3" coils and new stuff for the rear to do a 6/8 drop
ocbaud is offline   Reply With Quote
Old 03-24-2003, 11:32 PM   #2
C&C Chevy
C&C Chevy's Avatar
Yeessss.....let gravity take over......
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 03-24-2003, 11:38 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Once you start, it's never enough. It's a sickness I tell you.
Sorry to hear of the bad news, but it does give you an excuse to go down.
Oh, and not to be so anal, but it's not a hub, it's a rotor. :p
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-24-2003, 11:42 PM   #4
ocbaud
after seeing low87's thread, maybe 5/7 would be good.
i know the front shocks i bought from you would be good for up to 3" springs, but how low are the back ones good for?
i mean, i'm already gonna redo my front suspension with the new bushing set, and get my crossmember, and a-arms powder coated(hopefuly) so i figure why not go lower!
of course i'll have to get my new tires and new shortie headers first though
Old 03-24-2003, 11:57 PM   #5
low 84
low 84's Avatar
bag it
why not just bag it? kp components is coming out with a bolt on 4 link kit for our trucks that makes the install all bolt on. your gona want to do it any way once your 6/8 and you scrape every where, might as well save up and bag it. i'm doing mine next year
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-24-2003, 11:59 PM   #6
ocbaud
i would bag it, if i didnt need an engine more
Old 03-25-2003, 12:01 AM   #7
1FaastC10
1FaastC10's Avatar
ART already has a bolt on kit for our trucks. i thought about it, but all that extra equipment to run the bags is extra weight. sleeper trucks need to be light.
1FaastC10 is offline   Reply With Quote
Old 03-25-2003, 12:02 AM   #8
ocbaud
i would get a weld in 4 link btw
Old 03-25-2003, 01:20 AM   #9
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
WOW!! Dremel to the rescue!!! Glad you found the problem.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-25-2003, 01:25 AM   #10
Prerunner1982
Prerunner1982's Avatar
Eric... what did i tell ya?... it was the bearings.. we didnt grease them before we put them in.. DOH!
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-25-2003, 01:43 AM   #11
ocbaud
there should have been enough grease on there though, when i took it all apart today, there sure was a lot all over everything.
i checked the other side, and it was fine and really greasy also
Old 03-25-2003, 03:29 AM   #12
low 84
low 84's Avatar
art dosen't have a bolt in 4 link for our trucks. they have a bolt on cool ride setup for the front, and a weld in 4 link setup for the back of our trucks. the 4 link in back replaces the heavy leafs, and the front setup replaces the heavy coils, the air tank and compressor don't wiegh much at all, i'm betting i wll gain more from the better launch from a 4 link rear than i will lose from the negligable added weight
"i would get a weld in 4 link btw"
i'd rather not have to stress about getting the bars and brackets at the right angles, a bolt on set up is much easier to install and the brackets can be welded after everything is set up. if i do a bolt in i wil be able to install it all and drive it and make sure everything is perfect, and then go back and weld the brackets for added strength if i want.
'05 1500 Crew Cab
RIP
Old 03-25-2003, 04:01 AM   #13
1FaastC10
1FaastC10's Avatar
just noticed that... a buddy of mine was talking about bagging his 1 ton, and there is a kit available for that. assumed that they were producing them for 1/2 tons too... my bad.
Old 03-25-2003, 04:33 AM   #14
ironwood
$640 truck// doesn't run
I hope you are talking about a total of 6/8 drop and not 6/8 from where you are at now.?...? I think you might be wanting a hovercraft conversion if you go that low... You will scrape all of the rice off the road. Go get 'em.
Dave
I wish I could go low with my truck.
74 C-20 LWB
camper special
stock350/350
53 Chevy 1/2 ton- in California, where the rust is not. Ready for some LOVE!!!
ironwood is offline   Reply With Quote
Old 03-25-2003, 10:49 AM   #15
Low87
been here longer than Liz
Low87's Avatar
Come on Eric, join the club! Mike is right though, it's never enough once you get started. I want mine bagged now so I can go lower. Save money on this 'inbetween drop', skip it and go straight to bags.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-25-2003, 12:09 PM   #16
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
I say save up and do bags too..that is why i havent gone lower yet.
YOu dumbbutts didnt grease the bearings ??? dayum!! hahaha
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-25-2003, 11:58 PM   #17
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Wonder if Jon dropped anything on Eric's head
(inside joke )
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-26-2003, 01:10 AM   #18
1FaastC10
1FaastC10's Avatar
Brandon, there is still time... remember, they're going to drop Eric's truck some more.
Old 03-26-2003, 01:18 AM   #19
Prerunner1982
Talking
haha.... give me time..
Jon
Oklahoma Roll Call
Old 03-26-2003, 01:19 AM   #20
1FaastC10
1FaastC10's Avatar
can we get it on video this time?
Old 03-26-2003, 01:29 AM   #21
Prerunner1982
will see what i can do... maybe eric can put it on CD.... or on his site.. :-D
Jon
Oklahoma Roll Call
Old 03-26-2003, 04:02 AM   #22
79BIG10
79BIG10's Avatar
LOL I'd love to see it from that angle rather than the one getting hit!!
