Old 03-27-2003, 02:39 PM   #1
COBALT
COBALT's Avatar
New Intake Manifold water cooling plugs, necks, etc....
What do you guys use when setting up a new intake? With the new Performer intake I've put in I want to use something that will both work well with aluminum and not corrode and maybe even look good. I need both the water neck for the heater core which is 5/8" and a plug to go with it for a non-AC application.
I know I can just go down to the el-cheap-o parts store and get the basic zinc coated fittings, but I was hoping to get either aluminum or stainless steel. Brass is out because it doesn't mix well with aluminum...
Thanks.
If anyone has an angle on where to buy I'd love to know....
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
