Old 04-29-2011, 07:08 PM   #1
Leedogg
Dana 70 and 70hd Use different gear sets?
Looking on Ebay(and the net in general) for gearsets for my Dually with a 70 hd...but all I am finding are Dana 70 ring/pinions....but 70 and 70hd master bearing/install kits. do they use the same gearsets? And best I can tell- a 3.54 is the highest gear I can find for it, is that tall as they get?
I'd like to be able to pull my car at 75-80 at about 23-2500 rpm....possible with a non OD trans?
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 04-29-2011, 08:56 PM   #2
b454rat
Re: Dana 70 and 70hd Use different gear sets?
There are a bunch of variations of 70s out there, not sure what is different from one to the other. I know one of the model 70s that was put in the early Cummins trucks had 3.08s in them.
Check out Summit Racing or Ring-pinon.com, might be able to find the difference there.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-29-2011, 09:28 PM   #3
78customdeluxe
Dont hold me to it, but I'm pretty sure that the early cummins had whats called a dana 71 to house the 3.08's because of clearance inside the 70 housing. I know the fronts with 3.08's were actually a dana 61. Ring gears from a 60 will not fit in a 61, so i'm goin to assume that goes the same for the 70/71. I am fairly certain that any 70 gear set will fit in any 70 case. The differences are in the external bearing sizes. So you will want a bearing kit from a 70hd
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
Old 04-29-2011, 11:20 PM   #4
BIG V
yes they use different ring and pinions there is different offsets on the carriers. there is a explanation on www.ringandpinion.com
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
