Old 04-29-2011, 10:11 PM   #1
Duke66
Duke66's Avatar
Floor shifter
I did a quick search but didn't see what I needed. This is probably easy for the pros.
How do you know where to cut the hole to put in a B&M Mega shifter in the floor?
Thanks alot
1986 2wd 305 longbed
WTF have I done
Duke66 is offline   Reply With Quote
Old 04-29-2011, 10:15 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: Floor shifter
Thanks alot
all you need is a hole for the shift cable!...we are talkin automatic aren't we?
mooseknuckles is offline   Reply With Quote
Old 04-29-2011, 10:20 PM   #3
lakeroadster
Re: Floor shifter
I have installed (2) of these over the years. One of the advantages of a cable operated shifter is you place it wherever you want, as long as it is in reach of the cable.
lakeroadster is offline   Reply With Quote
Old 04-29-2011, 10:45 PM   #4
Duke66
Duke66's Avatar
Re: Floor shifter
Yeah sorry it's a TH350. That's sweet it's that easy.
Duke
WTF have I done
Old 04-29-2011, 11:17 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
Re: Floor shifter
You have to:
-Drill holes for the shifter
-Cut hole for shifter cable
-Cut holes in the carpet or mat
-Get under the truck and install the cable brackets and the lever arm for the cable. You will also need to adjust the cable
-Extend the neutral safety switch and reverse light wires to the shifter
-Trim the plastic shroud to match the contour of the floor
-Make some sort of bracket to hold stock shifter on the column in the park position
Not a tough job. Lots of fun to manually shift!
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-30-2011, 07:53 PM   #6
JBRAVO383
JBRAVO383's Avatar
Re: Floor shifter
and make sure the shifter cable is going through the floor as straight as possible.. mine had to much of a bend it it, resulting in me breaking the cable over time.
Thanks,
John
85' c10 swb 383 th400 ran:
13.26 @ 99 w/ a 1.8 60'
JBRAVO383 is offline   Reply With Quote
Old 05-01-2011, 06:32 AM   #7
andrewmp6
Re: Floor shifter
Once its in make sure the shifter works in every gear before starting the truck.
