Old 05-17-2011, 12:56 AM   #1
rcbildr
rcbildr's Avatar
Gas Tank Question
I have a 32 gallon tank from an 84 Burb I want to put in my 67. I want to drop the tank to clean it out (the 67 has sat for a loooong time) so I figure I'll try to upgrade while I'm at it. Will the stock gage in the 67 work with the sending unit from the 84 or will I have to find a way to use the gage from the 84? I kept it just in case. Any help will be greatly appreciated. Thanks!!!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
