Old 05-09-2011, 06:33 PM   #1
chevykevy
chevykevy's Avatar
What plug wires are you guys using?
I have been looking around for plug wire sets with enough wires of the proper length to run my wires the stock pattern. I have stock rams horns manifolds and an HEI distributor. I would like to run all four front plugs with the wires running between the mount and block as they were from the factory. Most sets don't have enought long wires to make it. I was hoping not to have to make the wires. Anyone find a set that works well?
chevykevy is offline   Reply With Quote
Old 05-09-2011, 07:31 PM   #2
Keller
Keller's Avatar
Re: What plug wires are you guys using?
I just dropped a new HEI distributor in my truck a few weeks ago. Making a custom set of wires isn't all that difficult. In my opinion it's the best way to go in order to get them to look and route the way that you want them to. I bought a Summit brand 8mm set that came with a crimper for just under 40 bucks. Pretty much pay for the crimper and get the wires free..
1972 C10 Longbed 350/350
Keller is offline   Reply With Quote
Old 05-09-2011, 08:01 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Ive HEARD you can use mid 70's vette wires they are for HEI and were routed between ram horns and motor factory..so ive heard..
John
1999 Toyota Tacoma 4x4
Old 05-09-2011, 08:09 PM   #4
Autoblueprint
Autoblueprint's Avatar
Originally Posted by Keller View Post
I just dropped a new HEI distributor in my truck a few weeks ago. Making a custom set of wires isn't all that difficult. In my opinion it's the best way to go in order to get them to look and route the way that you want them to. I bought a Summit brand 8mm set that came with a crimper for just under 40 bucks. Pretty much pay for the crimper and get the wires free..:metal:
I agree. I used a MSD 8.5 universal set on my HEI retrofitted 350 c.i.d. also purchased from Summit Racing.
The universal sets are long enough to configure the wire routing any way you want.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 05-09-2011, 08:54 PM   #5
chipflyer
chipflyer's Avatar
I have the same setup as you and bought plug wires from oreilly auto for a 75 vette. They came original with ram horns and HEI.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 05-09-2011, 09:34 PM   #6
chevykevy
chevykevy's Avatar
Thanks for the ideas guys. I was lost. I will take a look at both the vette plugs and the build your own.
Old 05-09-2011, 09:44 PM   #7
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I'm running Taylor Thunder Volt 8.2mm wires. That's probably overkill for you. In the past I've run Taylor Spiro Pro 8mm. I'd recommend either one. They are cut to fit and I have them run under my headers. Or there's Moroso.
What ever you do, do not, I repeat do not use Accel wires. I had a set of their 8mm 300F wires once and they are complete junk. One was cracked out of the box. Jegs or Summit replaced it (don't remember which). It wasn't long before another one cracked. They went into the trash after that.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 05-09-2011, 10:16 PM   #8
jhwkns
Registered Cruiser
jhwkns's Avatar
+1 on the Taylors.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 05-09-2011, 10:16 PM   #9
chevykevy
chevykevy's Avatar
Thanks Old Yeller
Old 05-09-2011, 11:06 PM   #10
byrd
Union Electrician
byrd's Avatar
3rd on Taylors 8.5 red, cut to fit
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-09-2011, 11:28 PM   #11
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
taylor's
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-10-2011, 04:09 AM   #12
mac808
mac808's Avatar
Anyone use/have feedback on Moroso wires...?
mac808 is offline   Reply With Quote
Old 05-10-2011, 04:45 AM   #13
dos0711
dos0711's Avatar
What's the best big block spark plug wire set for headers?
dos0711 is offline   Reply With Quote
Old 05-11-2011, 11:34 PM   #14
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I bought mine thru NAPA for a 1976 Corvette. The pic doesn't show full routing but, as you can see, the
front two come up through the engine mounts. Very tidy and secure.
Four years and nary a problem PLUS you can't even see my wires under the hood unless you are looking sideways for them.
Find the right clips for the oil pan to secure them as they travel below the block.
And be patient. This was the 3rd of 4 tries until I was satisfied. If done in-truck, it might be a project, but well worth it.
ETsC10 is offline   Reply With Quote
Old 05-12-2011, 07:20 AM   #15
MARKDTN
I only use 3 brands for pre-made wires. MOROSO, AC Delco, and Autolite. Any of the parts stores house brands I have had no luck with lasting. I have had very good luck with those 3. I have a set of MOROSO wires on my inboard boat.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-12-2011, 11:27 AM   #16
OJ1988
Just a car guy
OJ1988's Avatar
I have moroso street fire wires. 8mm black, look stock.
I got a set listed for hei under manifolds. Fit great and look stock.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 05-12-2011, 11:31 AM   #17
OJ1988
Just a car guy
OJ1988's Avatar
1973 Vega Drag Car
1970 C20 tow rig
Old 05-12-2011, 01:12 PM   #18
don t. - 72gmc
For my 70 GMC w/HEI, I also bought mine from NAPA (74 vette).
Wires were made by Belden wire and cable.
I routed mine on the valve covers and over the stock ex-mannys. No problems w/length.
FWIW....don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 05-12-2011, 05:16 PM   #19
Brewski*
Brewski*'s Avatar
Hopefully the MOROSO's in your boat are solid core wire. Street type spiral and any thing else can cause a major fire in a boat.
Brewski* is offline   Reply With Quote
