Old 05-25-2011, 10:42 PM   #1
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
difficult measurement
Can anyone figure a way to get me a measurement from the top of the radiator core support (right where the break or slant to the outside starts) to the inside of the hood. Another way of putting it is, what is the clearance from the top of the core support to the inside of the hood... with the hood closed, of course. I cant get it off my truck because the front clip is still off. I want to know if my supercharger tube on the passenger side will clear the hood... before I send it out for coating.
TIA,... Tom
Tom Vogel is offline   Reply With Quote
Old 05-26-2011, 08:52 AM   #2
71RestoRod
71RestoRod's Avatar
Re: difficult measurement
If you were building it for my truck... you'd have about 3" (+/- 1/4") between the top of the grill/radiator support and the hood at the center.
Note: You loose an inch at the outsides of the radiator support, underneath the hood stiffeners that run front to back.
...no warranties stated or implied with this measurement...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 05-26-2011, 10:41 PM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=71RestoRod;4701246]If you were building it for my truck... you'd have about 3" (+/- 1/4") between the top of the grill/radiator support and the hood at the center.
Do you mean the core support or the grill?
Old 05-26-2011, 11:52 PM   #4
71RestoRod
71RestoRod's Avatar
The radiator support. LMC calls it a Grille/Radiator support.
Old 05-27-2011, 08:14 AM   #5
Boneyard
I've checked hood clearance on an air cleaner by putting clay in a plastic bag on top. Close and open the hood then measure the clay. If someone could do this maybe they could post the measurement for you.
Boneyard is offline   Reply With Quote
Old 05-27-2011, 12:31 PM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
Mine doesn't have inner fenders so I could get in there to measure. Right at the pinch on the support where it turns down I had 3.25" to the hood going straight up. That pinch is about 1/4" high.
hgs_notes is offline   Reply With Quote
Old 05-28-2011, 10:26 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Awsome... its gonna clear just fine. Thanks Guys!!
Old 05-28-2011, 10:42 AM   #8
lakeroadster
Often you can use a regular retractable tape measure to obtain these types of measurements. Use a clamp to fasten the tape measure to a fixed object, pull out the tape and lock it. Slowly close the hood, the tape will be pushed back into the tape measure. Pop the hood and read the clearance.
Hope that makes sense...
lakeroadster is offline   Reply With Quote
