Old 06-24-2012, 06:06 AM   #1
bonehead
bonehead's Avatar
Stock wheels on disc brakes
I have just purchased a 66' c-10 that has the CPP disc brake kit installed with a 2 1/2 dropped spindle and tie rod adapter sleeve. The truck has 6 bolt rally wheels on it now. Will the stock 6 lug 15x5.5 steel wheels fit the disc brakes? I don't have one to try it yet, but I'm sure you guys will know before I buy one to try. If not, is there a stock wheel that will take the 1/2 ton stock hubcap that will fit the 6 lug disc brake setup?
thanks in advance,
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
current truck:
1966 C-10 Panel SWB
bonehead is offline   Reply With Quote
Old 06-24-2012, 07:41 AM   #2
fleetman
Re: Stock wheels on disc brakes
congrats on your 66. already haveing disc brakes is a big plus for your truck.
stock drum 66 steel rims rub on the caliper. they wont fit the front. you need
74-87 k5 blazer or 4x4 truck steel rims . these are the steel wheels you need.they have different design on inside of rim allowing more room for brake and stearing and suspension parts.
they have the nubs on them so you can use 66 stock hubcaps, too.
hth
also do a search in the suspension section for this topic. lots of info.
others will chime in too on this as it is popular topic.
paul
fleetman is offline   Reply With Quote
Old 06-24-2012, 07:51 AM   #3
bonehead
bonehead's Avatar
Thanks for the info fleetman. I love the stock wheel look for sure.
past trucks:
current truck:
1966 C-10 Panel SWB
Old 06-24-2012, 11:00 AM   #4
jocko
jocko's Avatar
I believe 71 (vice 74)-87 K10 will fit since Disks came out in 71 as an option. Truck wheels have to be off a K10 only (or a blazer as mentioned) to be 6 lug.
They may take a little while to find, but worth the wait, as the steelies look great and they will clear the calipers. Check out the parts board on here in both the 67-72 and 73+ sections.
Old 06-24-2012, 11:29 AM   #5
NCD1966
NCD1966's Avatar
found some 6 lugs 15x8 on ebay. would look pretty sweet with 8s in the back and 6s in the front
http://www.ebay.com/itm/4-55-59-60-6...#ht_500wt_1413
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 06-24-2012, 01:48 PM   #6
bonehead
bonehead's Avatar
Thanks, I'll start looking around and beating the bushes for them. I want the 15x6 wheels and would trade my 15x7 ralleys.
past trucks:
current truck:
1966 C-10 Panel SWB
