Old 06-15-2011, 09:15 PM   #1
hatzie
Moderator
hatzie's Avatar
1985 tilt column in 1976 cab?
Has anyone tried this?
I have a 1985 tilt column in a rusted out donor cab.
Will the 1985 column bolt into a 1976 cab?
Will I need to move or swap the firewall plate or U bracket?
I'm not asking about the wiring differences. They can be sorted... I have GM Helm Inc. schematics for 1973-1986 gm trucks.
The donor has cruise and pulse wipers. I have the whole cab so I may just grab the entire cab harness and re-pin the engine compartment firewall connectors where needed.
Old 06-16-2011, 08:14 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 1985 tilt column in 1976 cab?
HMM Nobody?
Old 06-16-2011, 08:33 PM   #3
trout
should be a strait swap minus wiring
Edited by staff
trout is offline   Reply With Quote
Old 06-16-2011, 08:47 PM   #4
hatzie
Moderator
hatzie's Avatar
Thanks. I like to know what I'm getting into. The ATC fuse panel will be a nice upgrade too.
Old 06-17-2011, 07:30 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
that is a few projects down the line for me
but 88 or 89 to 78
what i've read the wires are the problem
i believe it was different 77 and before and 78 and after
hope you figure it out..........and post
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-17-2011, 09:42 PM   #6
ray_mcavoy
Hi hatzie,
I believe GM changed from a splined shaft to a double-D shaft at the lower end of the steering column sometime around 79. Shouldn't be a problem though ... just use the matching intermediate shaft from the 85.
ray_mcavoy is offline   Reply With Quote
Old 06-17-2011, 11:41 PM   #7
BIG10
BIG10's Avatar
My 78 has an 85 tilt column, but my uncle had it all installed when he owned the truck so I don't know details of the installation. The intermittent wipers work properly though, so I know for a fact that it can be done.
Jay
1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser.
BIG10 is offline   Reply With Quote
Old 06-18-2011, 12:36 AM   #8
hatzie
Moderator
hatzie's Avatar
I am planning on a Jeep XJ shaft to replace the rag joint at the same time but that's an important gotcha.
I'll post the wiring when I get it sorted.
