Ball joint to short?????
I have a 68' c10. Had lower ball joints put in a few weeks ago. Well now that i am putting in the new springs the ball joints are to short for the spindle. Are all 67-72 1/2 ton trucks the same?
Re: Ball joint to short?????
The 67-70 were different from the 71-72. They came out with disc brakes & changed some of the front end parts.
67-72 parts collector,…
![]() Join Date: Nov 2002
Did you change spindles?
Just changing springs should change anything with the balljoint.
x2.
Well I got it figured out. Front suspension changed by PO and my 68 now has a 71 front end.... What a pain... Allready had the new ball joints put it!!!
So it does have disc brakes already.
#7 | |
On the fast track to nowhere..
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
Ah... Why you putting me out like that Mike!!!!
