Old 06-27-2011, 10:43 AM   #1
skeebo23
duel fuel tank problem
hey guys, bought a 1987 chevy tbi, 350, swb
great truck has 97,000 orig miles and runs awesome!
problem is i cant get it to switch from passenger tank over to drivers side tank. When i switch in cab, it dies quickly.
I have replaced the in cab switch, as well as the fuel tank selector valve under the truck. i do not hear anything when switching over, nor does the gauge change. not sure how to troubleshoot!
thank you in advance for any suggestions or remedies.
skeebo23 is offline   Reply With Quote
Old 06-27-2011, 12:03 PM   #2
J Knight
J Knight's Avatar
Re: duel fuel tank problem
I think 87 tbi trucks have fuel pumps in the tank. Maybe the pump in left tank is bad. Maybe check plug conections on selector valve. Just some ideas.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-27-2011, 12:05 PM   #3
skeebo23
correct, problem is i cant get it to switch over to left tank at all. i just put new selector valve on, and all connections are good. Also replaced tank switch in cab as well.
Old 06-27-2011, 12:09 PM   #4
J Knight
J Knight's Avatar
Maybe a bad wire between in cab switch and selector valve. What was happening before you changed parts?
John
Old 06-27-2011, 12:21 PM   #5
skeebo23
nothing, i changed the parts in hopes it would fix issue, i bought truck a few months ago, and drivers side tank was not working when i purchased ( i was told ), so this is what i have done so far in hopes to fix it.
Old 06-27-2011, 12:48 PM   #6
MadManAndrew
As mentioned above, that only leaves the wires and the fuel pump. The truck dieing when you switch it over means that your passenger side pump is shutting off, and your valve is switching leaving you with no fuel if your driver side isn't coming on. Also, your truck probably will die if you switch it over with it running. You need to kill it, switch it over, then start it back up.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 06-27-2011, 12:50 PM   #7
skeebo23
i was under the impression that when you switched in cab to other tank, you would hear the selector valve. i am not hearing it at all, so i feel its not actually switching over to the tank, so i guess i need to check power to the valve and or ground?
Old 06-27-2011, 12:55 PM   #8
MadManAndrew
I don't know if you'll be able to hear it or not, but if you think your problems with the valve, yeah, that'd be a good place to start. I would ask around or try to get my hands on a voltimeter in your case, it would make things a lot easier.
Old 06-27-2011, 05:24 PM   #9
J Knight
J Knight's Avatar
Not to sound insulting, but does the left tank have gas in it? I've seen the obvious overlooked more than once.
John
Old 06-27-2011, 06:41 PM   #10
baclay9
I can hear the valve changing sides clearly in mine. Also, you should be able to switch it over with the truck running without issue. I would start with the wireing to the selector valve.
baclay9 is offline   Reply With Quote
Old 07-05-2011, 10:02 AM   #11
skeebo23
thanks guys, will start to trace wires from in-dash switch back to selector valve, will update if i find anything
Old 07-05-2011, 10:33 AM   #12
J Knight
J Knight's Avatar
I still think its the left tank fuel pump. Let us know what it was when you get it fixed.
John
Old 07-05-2011, 10:35 AM   #13
skeebo23
i will do, just something tells me something else, also when i do switch over to left tank, my gauge doesnt change either, so something doesnt seem right, but i have an extra fuel pump that works, its older, but works, so not too much trouble to test your theory, so will keep you posted!
Old 07-05-2011, 11:56 AM   #14
J Knight
J Knight's Avatar
Uh oh, the gas gauge not working when you change to left tank changes everything. The selector valve makes the switch for the gauge. I would pull the fuel lines off of the valve that go to the left tank to see if fuel pump is working.
John
Old 07-05-2011, 12:00 PM   #15
skeebo23
yea i guess i forgot to mention that, i am not getting it to switch over at all at the selector valve, its brand new, as well as the dash switch, guess i'm going to have to do some electrical tracing now
UGH!
Old 07-05-2011, 12:13 PM   #16
J Knight
J Knight's Avatar
This is going to be a puzzler!!!
John
