Old 07-10-2011, 01:48 AM   #1
84Longbed
drop spindles question
I searched but nothing came up so here goes
I mentioned to a guy in my manual lathe class that I was lowering my 84
He said he had a set of brand new Belltech drop spindles laying in his garage, and is giving me a great deal on them
Only problem is they were for a 92 1500 2wd, my ride is a 84 c10 2wd
Will they fit without much modification? Like maybe I can just change balljoints or somethin?
They look the same as spindles for my generation truck so I can't tell a difference
Thanks for any advice
84Longbed is offline   Reply With Quote
Old 07-10-2011, 10:57 AM   #2
J Knight
J Knight's Avatar
Re: drop spindles question
No, they will not fit at all.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-10-2011, 12:53 PM   #3
njlimbaugh
Just for reference, according to the catalogs, '73 through '87 uses the same setup.
njlimbaugh is offline   Reply With Quote
Old 07-10-2011, 01:00 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
There are two different types of spindles for squares one for 1" wide rotors and one for 1.25, which use different rotors, spindles, bearings, calipers, and brake hoses.
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-10-2011, 01:55 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
x2
The '92 spindles will not work.
www.performanceonline sells spindles every day for $228.
Make sure youu check the width of your rotors before buying anything.
Keith
Convert to disc brakes.
Old 07-10-2011, 08:52 PM   #6
84Longbed
Im aware theres the spindles for a 1" rotor and a 1.25", but I can get around that. I was thinking there were modifications I could make to fit the 92 spindles on my truck, not just bolt them on. The deal is just too hard to pass up, being that they've never been used, and hes only charging me less than half of what I'd pay at performanceonline. Thanks anyway
Old 07-10-2011, 08:55 PM   #7
J Knight
J Knight's Avatar
It would cost you more in fabrication and parts than it would cost to buy correct spindles.
John
Old 07-10-2011, 09:01 PM   #8
lolife99
lolife99's Avatar
The '92 trucks have a totally different suspension geometry.
Maybe buy them and make a few bucks.
I would still buy the correct spindle.
If you really want to use them on your '84,... you will need to use:
'92 upper ball joint
73-87 3/4-ton lower a-arm
'92 lower ball joint
'92 outer tie rod end.
Keith
Old 07-10-2011, 09:04 PM   #9
J Knight
J Knight's Avatar
Would the 92 tie rod(possibly metric) fit the square body sleeve(possibly standard)?
John
Old 07-10-2011, 09:09 PM   #10
84Longbed
Thats the info I was looking for
Ill check the local junkyards for the 3/4 ton lower a arm
Until then, I have drop springs I can install
Thanks man
Old 07-10-2011, 09:10 PM   #11
lolife99
lolife99's Avatar
Maybe I'm wrong on the tie rod.
Look here:
http://www.67-72chevytrucks.com/vboa...ighlight=88-98
This thread is about a '68,... but the 73-87 trucks still apply.
I still don't know about the tie rod,...
Keith
Old 07-10-2011, 09:14 PM   #12
84Longbed
I dont know about the tie rods fitting or not, Ill have to check into that. Ill search for that thread you mentioned
Old 07-10-2011, 09:24 PM   #13
lolife99
lolife99's Avatar
Here's the parts list from that thread:
1968 C20 lower control arms (in your case,... 73-87 C20)
1990 3/4 ton Light Duty 2X4 must have (1.25" rotors) spindles
1990 1.25" thick 6 lug rotors
1990 calipers off same truck
1990 upper and lower ball joints
1990 outer tie rods
inner tie rods MOOG part #ES2020RL
1990 style tie rod coupler
STILL easier to buy the correct spindle!
I forgot about changing rotors and calipers.
Now it looks like inner and outer tie rods and a tie rod coupler.
Bottom line,... alot more money
Keith
Old 07-12-2011, 03:11 PM   #14
burger
Is there some advantage to using the '88-'98 parts?
burger is offline   Reply With Quote
Old 07-21-2011, 07:33 PM   #15
84Longbed
Don't kno of any advantages other than the price I could get these for
Old 07-21-2011, 07:49 PM   #16
rwhit57
rwhit57's Avatar
This sounds like my wife driving across town to buy toilet paper on sale. She burns up $10 bucks in gas and comes home bragging about saving $2. Sorry couldn't resist. Even if they were free, you're out alot more time and $. Do what the one guy said, buy them, sell them take the profit and buy the right ones. A whole lot easier.
rwhit57 is offline   Reply With Quote
Old 07-21-2011, 10:41 PM   #17
Stepper562
Stepper562's Avatar
So damn true about the wife part...Same problem here. Mine buys a pallet, comes home and brags about saving 5 bucks on a pallet of toilet paper which she spend 50 bucks on hahaha.
Stepper562 is offline   Reply With Quote
Old 07-21-2011, 10:46 PM   #18
bigwheel15
bigwheel15's Avatar
Id buy the spindles then sell em. Use that money towards a set of correct drop spindles if for nothing else but ease of installation.
bigwheel15 is offline   Reply With Quote
Old 07-21-2011, 11:42 PM   #19
SCOTI
SCOTI's Avatar
Ding, ding, ding....
These would be worth it if a guy had access to a donor 88-98.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
