Old 03-25-2012, 11:35 PM   #1
Jacob's 72
Jacob's 72's Avatar
My Rustoleum Adventure
Well i decided to go the rustoleum route on my truck after reading quite a few threads on here. Thanks everybody for your info. Anyways, I used the purple harbor freight gun and a friends air compressor to shoot rustoleum satin #7777. I feel like it turned out pretty good for never painting any cars before.
Jacob's 72 is offline   Reply With Quote
Old 03-25-2012, 11:47 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: My Rustoleum Adventure
Yep look's good!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 03-26-2012, 01:03 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Nice job, first time effort or not. And welcome to the site.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-26-2012, 02:56 PM   #4
yuccales
yuccales's Avatar
That truck looks good.
yuccales is offline   Reply With Quote
Old 03-26-2012, 03:24 PM   #5
chevy88
chevy88's Avatar
Nice job, what did use for thinning mineral spirits or laquer thinner and what was you mix ratio?
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 03-26-2012, 03:28 PM   #6
socalkevin68
socalkevin68's Avatar
looks awesome..wish my truck looked that good!
socalkevin68 is offline   Reply With Quote
Old 03-26-2012, 03:29 PM   #7
Pop's C-10
Pop's C-10's Avatar
nice job
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-26-2012, 03:32 PM   #8
Lemield
Lemield's Avatar
Looks great!
I did mine with Rustoleum and a roller....still looks pretty decent....
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 03-26-2012, 05:07 PM   #9
jchav62
1962 C-10
jchav62's Avatar
Welcome. Looks nice!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-26-2012, 05:34 PM   #10
Jacob's 72
Jacob's 72's Avatar
Thanks everybody. i used acetone for the thinning material at about 20%. It was about 75 when i sprayed the bed and around 60 degrees when i did the cab. not much changed with the temp, bout an hour on drying time was it. Wetsanded everything with 400 grit paper before i sprayed. My dad went to school for bodywork back in the 80's so the few tips sure paid off in the end.
Old 03-26-2012, 06:27 PM   #11
tjvending
tjvending's Avatar
Originally Posted by Lemield View Post
Looks great!
How did yuo keep the roller masrks out? I tried this, look good but I have those roller marks from lapping, Let me know..TJ
tjvending is offline   Reply With Quote
Old 03-26-2012, 06:28 PM   #12
tjvending
tjvending's Avatar
Did you have to wet sand between the coats? How many coats..TJ
Old 03-27-2012, 12:33 AM   #13
Jacob's 72
Jacob's 72's Avatar
I only wet sanded before spraying, and i put down two pretty solid coats. The second coat was applied once the first began to tack, which didn't take very long. I also went over the entire surface with paint thinner after wet sanding to get it good and clean. Hit it with a tack cloth right before spraying. Covering the entire floor with water wherever you are spraying helps cut down on quite a bit of dust as well.
Old 03-27-2012, 09:18 AM   #14
midniteblues
midniteblues's Avatar
lots of people say the rustoleum paint just doesnt cut it.but some times its not a bad choice touch up,color match,availability, and cost compared to the better paints makes it a no brainer for some.my kid practically didnt even know what a spray gun was till I put it in his hand and said "do it like this". he did our truck and it turned out great.maybe one day it will get a top job done but for the time being the rustolem makes it one color instead of ten different colors with primer here an there.looks like you did a very nice job on yours and Im shure your happy that its one color too.One thing though is that I would like to see some of the other colors done. Ive only ever seen the black witch is ok,except in the one mag they did a little f**d with a roller and lots of wet sanding that one was off white.good job it looks great and the best part is you did it yourself
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-27-2012, 09:24 AM   #15
70cst
70cst's Avatar
Very nice job
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-27-2012, 09:30 AM   #16
LEX
LEX's Avatar
Looks really good. Anymore pics?
LEX is offline   Reply With Quote
Old 03-27-2012, 10:32 AM   #17
MrSchaeferPants
MrSchaeferPants's Avatar
Good job man, I'll be tackling that in another month or two. I did just start my tailgate, wanted too see it completely done to insure the color I picked was something I liked. All the brackets are done, tailgate is in primer, gunna finish shooting the tailgate today. Probably won't turn out as good as yours, it's a work truck, I just want the rust gone, and the body protected. Don't think I have what it takes to sand and sand...
Oh btw you add a hardner?
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 03-27-2012, 02:52 PM   #18
Dano69c10
Dano69c10's Avatar
Did you sand to bare metal or sand 400 grit over the existing paint?
Thanx
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-27-2012, 03:14 PM   #19
Lemield
Lemield's Avatar
You have to thin the paint to skim milk consistency with mineral spirits...the key is several thin coats...wet sand every two coats...don't want to hijack this thread...do a search on Rustoleum and you should find my old thread.
Larry
Old 03-27-2012, 03:57 PM   #20
VWNate1
VWNate1's Avatar
Thumbs up Re : Looks Nice !
...And I don't even like satin paint jobs .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 03-27-2012, 08:20 PM   #21
Jacob's 72
Jacob's 72's Avatar
Thanx
I only sanded to bare metal where i needed to apply bondo. Other than that just getting the surface smooth is the point. And no i didn't add any hardener. i think that i probably should have though. Maybe on the next one
Old 03-27-2012, 08:42 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
Hi
It looks great
i rolled blue to red last year.....called tremclad up here
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-29-2012, 01:32 PM   #23
Dano69c10
Dano69c10's Avatar
Thanx for the info!
'69 Fleet
Old 03-31-2012, 09:47 AM   #24
RCbowtie69
RCbowtie69's Avatar
Looking good & not bad for your first time.Keep on Truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 03-31-2012, 09:57 AM   #25
72 Super
72 Super's Avatar
Turned out very nice!
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
