Old 10-24-2011, 12:25 AM   #1
California gold 68
California gold 68's Avatar
Transfer case help
Here's one. What type of transfer case came in a 1983 K30? I'm looking at buying a retired CDF truck with a 350,turbo 400, 14 bolt rear and a stout looking Dana 60 up front. Thanks in advance.
California gold 68 is offline   Reply With Quote
Old 10-24-2011, 01:05 AM   #2
Redcap
Re: Transfer case help
Should be a 205, but could be a 208. Is the case cast iron? In between the front output rear bearing support and the rear output, is there a little 3-bolt cover? If yes to these two questions, it is a 205.
Best bet is to take pictures of the T-case and post them.
Redcap is offline   Reply With Quote
Old 10-24-2011, 08:49 AM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Pictures would be helpful. It would be a NP205 or NP203.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-24-2011, 09:58 AM   #4
mud slut 350
mud slut 350's Avatar
like chevy said i should be a 205 or 203 like red said if its got a 3 bolt middle cover on the back its a 205 if not its a 203 and if its aluminium, which i doubt it is, its a 208 but more than 99% sure its a 205 or 203
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
Old 10-24-2011, 12:04 PM   #5
Your41Plague12
Your41Plague12's Avatar
Shouldn't be a 203 in an 80's truck. Most likely an NP205 in a 1 ton, but could be an NP208. I'm 95% sure it should be a 205.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-24-2011, 01:03 PM   #6
maskale
goggle pictures of them and discription, take that knowledge with u when u go look at the truck.
maskale is offline   Reply With Quote
Old 10-24-2011, 01:50 PM   #7
Redcap
It is a nearly 30 year old truck...it could be anything at this point.
Old 10-26-2011, 05:38 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I bet its a 205 since its behind a Th400. The easiest way for me to tell the 205s apart are that they have a fill plug and drain plug and the 203s only have a fill plug.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-26-2011, 08:47 PM   #9
scooter122983
The Man The Myth The Mystery
or you could just look at the shifter if you are debating a cast iron or aluminum transfer case.
scooter122983 is offline   Reply With Quote
Old 10-26-2011, 09:35 PM   #10
Redcap
I don't get it.
Old 10-26-2011, 09:51 PM   #11
kwmech
Originally Posted by Redcap View Post
I don't get it.
A 205 shifter will have the rod coming thru the floor where as a 208 shifter is floor mounted
