Old 08-29-2011, 05:33 PM   #1
tiberiusx
power windows
I have read several posts regarding power windows. my issue was low voltage at the switch only 9v.. where i could only hear a couple clicks but no movement. I saw the posts re adding relays one for up and one for down and this apparently does the trick ..Well i picked up some relays but what if I just run a new wire from the firewall constant 12v attach a fuse and then just operate the window using the switch as usual any issues with this method?
tiberiusx is offline   Reply With Quote
