Old 09-09-2011, 08:49 PM   #1
wjr
67 4x4
i want to make my 67 lwb 2x4 into a 4x4, i have a 86 3/4 ton 4x4 chassis has anyone put tyhis body on this frame ? thgere is not a possibility of me finding a 67-72 4x4 frame so this is what i have to work with. any info would greatly appreciated and web sites of this transfer that has been done. thanks, im not worried about the cutting grinding,welding i just need the specs thanks
wjr is offline   Reply With Quote
Old 09-09-2011, 10:10 PM   #2
wjr
Re: 67 4x4
or would it be easier to con vert my 2 wd frame to a 4x4
Old 09-09-2011, 10:39 PM   #3
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Re: 67 4x4
What he said^ My brother in law put a 68 onto a 73 4x4 chassis. Nothing lines up, the hump in the frame under the cab is in the wrong spot, the rad support doesn't line up where it should and I think the wheelbase was longer on the 73..? I don't think he'd do it again.
Probably much easier to swap your crossmember(s) and install some front leaf springs.
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 09-11-2011, 11:30 AM   #4
67mater
67mater's Avatar
Re: 67 4x4
yes, full body swap requires all new mount locations. May be easier to move the later model suspension mounts onto your 2wd frame. no welding required!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 09-11-2011, 11:51 AM   #5
snj8198
snj8198's Avatar
Re: 67 4x4
Are you looking for any lift? or are you wanting roughly a stock height 4x4?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-11-2011, 03:43 PM   #6
brett3xx
Re: 67 4x4
I have a 67 2wd that Im going to convert to 4wd. Im also going to shorten the lwb frame to swb. The front swap shouldnt be to bad, but I havnt been able to find alot of info on the rear. Ill need to swap my rear coilds out to leaf springs, I do alot of fab work so Ill probably just build a set of spring hanger. Ill be adding a 6" lift to mine during the conversion
brett3xx is offline   Reply With Quote
Old 09-16-2011, 12:36 PM   #7
wjr
Re: 67 4x4
thanks for the info guys i thought it looked like the hump in the frame was in the wrong place,so i guess i won't get in to it this deep i'll look at other options,i made a 86 crew cab 4x4 once and it turned out to be a pretty good job don't want to do that again so this info changes my mind thankls again
