Old 04-10-2003, 04:52 PM   #1
crazy longhorn
Fabricate till you "puke"
test run on the longhorn....6 gears!
The weather was good enough to try out the Richmond trans! nice easy run(no plates ) Man thats a set of gears in that box. 3.28 1st x 4.10 gears really puts her low....hard to keep from barkin the tires under normal driving! 6th gear sets the tach @ 1500 @ 40mph. my first run would indicate that 3.73 s would be a better overall gear, but im gonna run her for a while & see how it goes. i still have a set of 3.40s.....but that booger would be flat flyin down the hyway @ 2500 in OD! Crazy L with a big
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
