This new girl has a problem!
Hi everyone! My first post!
![]() On hot days (above 93) my truck ('72 Cheyenne Super) runs really rough and if I don’t play with the gas and keep high rpm it dies and won’t start until it cools down a little and then only if I hold the gas to the floor as if it were flooded. There is no cooling problem as the temp stays around 195. My boyfriend thinks it’s vapor locking but is there another possible explanation? Thanks! |
10/30/19
Re: This new girl has a problem!
Welcome to the board..Its sounds like your boyfriend is correct. I had an old falcon with an electric fuel pump that would vapor lock on hot days.
Fight the good fight, finish the race, keep the faith |
Welcome! If it has a filter in the engine compartment make sure its on the pressure side of the pump and not the suction side.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
I am a Referee of life.
You might also look at the way the fuel line is routed.If it runs near manifolds,or exhuast ,you may be able to reroute it to keep the fuel cooler in it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#5 | |
Champagne Taste on Beer Budget
Plus keep the fuel lines away from the raditor hoses if it all possible as well. Good luck and welcome to the board!! ![]()
Coming Soon: Project 1970 Country Truck |
Junior Member
Good suggestions in previous posts. What engine and carb does your truck have?
Some carbs, especially Edelbocks, are affected by heat some and need a phenolic spacer between them and the intake to prevent float bowl boil problems.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Thank you so much for the warm welcome and advice!!
I'm pretty sure the filter is on right since this only happens on hot days. Totally agree with checking the lines for heat sources. I have a spacer on the intake for the quadrajet carb, but perhaps need a thicker one? I’m also thinking of getting a 185 thermostat, which was the original anyway. By the way, here's a picture of my baby! ![]() |
Nice truck!
Wow!
Nice looking truck. And it's kinda cool to see a bed that is painted white too.
![]() Join Date: Sep 2010
![]() Welcome from Upstate NY! Beautiful truck! I'm really glad you brought this up because my truck was running poorly during some very hot weather earlier this summer. I'll be looking at this over the weekend. |
Interesing you should say that about the bed. We're not crazy about it. Thinking about a wood bed, in which case the sides would be red, I assume. And the top of the cab needs to be white, of course.
Its a Truck Thing......
Nice Truck.....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
You can try clipping wooden clothes pins to the fuel line. Put as many as you can fit. The wood will act as a heat sink. This is not a pretty fix but it may help you diagnose that it is in fact a vapor lock issue.
#14 | |
Junior Member
Q-jet carbs are also bothered by heat. A metal spacer does little to help with that, it has to be phenolic. Also Q-jets have a problem with leaks in the bottom of the carb that can cause problems. I usually run a 180 degree thermostat, but 185 should work also.
#15 |
I think you have my trucks twin! Nice truck and welcome from Kansas. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
#16 |
![]() Join Date: Nov 2003
If your timing is too far advanced it can do the same thing.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#17 |
![]() Join Date: Sep 2004
Another good idea there. That usually makes it hard to start too.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
#18 |
![]() Join Date: Jan 2008
Welcome to the board from Florida! Nice truck! And nice to see another chick into these trucks! You are at the right place!!!
#19 |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#20 |
Clothes pins on a fuel line? Was that optional equipment for trucks destined for hot climates? Come on, we have a female who likely doesn't want to be "taken for a ride". Show some professionalism. Now for my comment...
In addition to the vapor lock problems, check the fuel pressure, as vapor lock can be a sign of a failing fuel pump. In addition, the problem could be over heating, float level set to high. What engine and carb does the engine have?
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
#21 |
Looks good at 20-ft .....
No BS ---- that clothespin thing works. Ugly, but it works.
My first car was a '50 Chev 2 dr & it had three clothespins on the metal fuel line to that mighty inline 6. I thought: "What's this cr*p?" & took them off. Wouldn't start at all when it was hot. Put them back on, & it'd go. I went "high-tech" & wrapped the fuel line loosely with aluminum foil, & that worked too. Didn't look much better than the clothespins, but it worked. |
#22 |
have you checked to see if you have the right gascap? if you take the gascap off and here a wooshing pressure/vacume sound you have a bad gascap causing fuel starvation
#23 |
I always run 180 degree thermostats in these trucks.
#24 | |
Even though you were being a smart ass I will answer your ridiculous question about new trucks in hot climates, Obviously clothes pins on the fuel line was not an option. When these trucks were new off the line they did not have weak fuel pumps, re-routed fuel lines or any number of other changes that may cause a vapor lock issue. Seems to me you are the one who needs to "show some professionalism."
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 09-03-2011 at 02:41 PM. |
#25 |
It's all in the timing
68shortstep and OhOneWS6,I would agree with you both,the clothes pin trick does work for trouble shooting the problem.My father was a hot rodder back in the 50's when there was not a speed shop or auto parts store on every corner.You had to make do with whatever parts you could find or salvage to build your car.(Rat Rod) I think the problem is in todays world is if you dont read it in a book or plug a cpu in to tell you whats wrong must people think its BS.Babydoll,did not mean to hijack your thread with my rant.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
