Old 09-06-2011, 03:04 PM   #1
H8PVMNT
Harris Performance TBI chip...
Just installed the Harris Performance Inc Towmaster chip in my '88 1 ton crew cab and took a 500 mile tow/road trip to pick up a milk cow (banjos playing in background).
These things really work! Throttle response and acceleration was much improved as well as a noticable difference in power wile pulling hills. Milage was the same as before at around 10 mpg. I haven't got to drive with it much unloaded since putting in the chip. I was getting 10 mpg loaded, unloaded towing etc. so I'm guessing this will be the same.
It also idles much smoother than before.
It's nice to have a 5 minute install make a noticable difference.
H8PVMNT is offline   Reply With Quote
Old 09-06-2011, 06:30 PM   #2
franky69c10
chevy runs deep
franky69c10's Avatar
Re: Harris Performance TBI chip...
When putting in the new chip do u have 2 reset the timing and how much did it run u ?
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 09-06-2011, 07:05 PM   #3
meter swinger
meter swinger's Avatar
i'm all ears, i need to do this on my 88 1ton.
meter swinger is offline   Reply With Quote
Old 09-06-2011, 07:33 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Brian is a genius! His stuff is the bomb! He'll be making me a custom chip when I put the Vortec 383 into my 88 burb. I'd never buy from someone else.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-07-2011, 08:25 PM   #5
H8PVMNT
The chip was $130 to my door.
The timing is set to factory specs and you are suposed to run 91 octane or if you switch to a 180 thermostat you can run 87. Honestly though I had both tanks full of 87 when I installed it and the truck ran just fine anyway. No noticable pinging or anything like that... Might have to do with the elevation here. I ran 91 since then and I have a 180 thermostat sitting on the seat waiting to be installed.
Since I posted I ran to town unloaded and all over town and I think I picked up a mile per gallon there.
Old 09-07-2011, 08:27 PM   #6
camshaftgsxr
camshaftgsxr's Avatar
how does this compare to a performance carburator?
camshaftgsxr is offline   Reply With Quote
Old 09-07-2011, 08:31 PM   #7
H8PVMNT
I don't know since I've never ran a 454 with a carb. I'm sure you could get more kick out of a carb setup in general since you can simply throw more fuel in there with a good carb, but for guys with TBI who want to run TBI but juice it up a little I think it's a viable upgrade comparing the stock chip to this one.
Old 09-07-2011, 08:41 PM   #8
SCOTI
SCOTI's Avatar
Contact link? Did you have to do any other adjustments (bump fuel psi etc....)?
I'm still working on getting my 461 back into the bay. I went w/flat-tops, a Mellings towing/RV cam, Edelbrock TBI intake, ditched the air pump set-up, & added 1.75" x 3" collector long tube headers. Sounds like one of his chips would serve me well....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-07-2011, 10:19 PM   #9
thirdstreettito
Resident of Here
http://www.tbichips.com/
He is a helluva guy. Real smart, he and I planned out everything for my Vortec 383 for my 88 burb.
~Bradley~
Miss having a truck
Old 09-07-2011, 10:26 PM   #10
SCOTI
SCOTI's Avatar
Ahhh.... I didn't realize it earlier but that's who I was already considering.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2011, 11:26 PM   #11
H8PVMNT
100% sure now I'm definately getting better milage than before. Still haven't ran any numbers but it takes about 1/8th less fuel to drive to town and back now.
Old 09-12-2011, 01:41 AM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Awesome I might have to check his stuff out. Thanks for posting feedback and getting a link up its much appreciated
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
