Old 09-09-2011, 08:33 PM   #1
Breadman
Breadman's Avatar
What do you think ?
I traded for a 73 chevy C-10 long bed. It HAD a 250- 6 cyl in but it has been replaced with a 1965 model 327. It still has the low gears in rear end and the 3 speed that was used with the 250. It sounds like riding around in 2nd and has
bad gas mileage. OK here is the question.For better gas mileage would you !!!
1. Leave the 327 in it and just change the gears to 308 or so.
2. Put a 250 back in it and leave the gears along.
3. Or do you have a better idea, If so tell me about it.
Truck will be used for daily driver and pull my boat
I'm new here and proud of it.
Breadman is offline   Reply With Quote
Old 09-09-2011, 08:36 PM   #2
Clyde65
Clyde65's Avatar
Re: What do you think ?
I would put a 4speed auto in it, or a 5speed manual. That would make it easier on fuel...well a little easier.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-09-2011, 08:38 PM   #3
camshaftgsxr
camshaftgsxr's Avatar
what he said, low gears for towing and an over drive for highway
camshaftgsxr is offline   Reply With Quote
Old 09-10-2011, 10:02 PM   #4
Breadman
Breadman's Avatar
That is all well and good and might do that if the funds were there.If I go the way of
just changing gears I'm sure someone around home would trade for the 411 or 373
that's in it.Have not checked to see what's in it yet. If I went the 250 way I know
somebody would give there 6 cyl for this very goon running 327 I have.
Thanks for the help.........Still looking for more
Old 09-10-2011, 11:40 PM   #5
cr34t3d_by_d4rkd3n
gonna state the obvious. drive a honda. buttttt id reccomend a th350. u know itll fit. get it from a truck of similler year. a 5sp manual would b slick but ur lookn at alotbof custom fab
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 09-11-2011, 02:17 AM   #6
67_SS396
Swaping from a three speed manual to a th350 will not improve your mileage enough to justify the cost or effort. First, determine what rear gear it has and go from there. 3.42-3.56 is a good all around ratio without OD, in my opinion. I wouldn't go less than 3.23.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-11-2011, 05:36 AM   #7
sumran
sumran's Avatar
Congrats on the new truck and welcome to the forum. Pictures are always welcome.
What tranny do you have? What carb? The 250 is not that economical. What type of driving do you do? If your driving is relatively open areas, as opposed to congested city driving, a 700r4 would work well. That may be a cost that doesn't fit your budget at this time. If the 327 is well tuned, has a 4-barrel with small primaries and can breathe well it will do better. You might be able to make your mileage better. It will always be low.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 09-11-2011, 07:04 AM   #8
cr34t3d_by_d4rkd3n
u can find a 1000doller parts truck. What rebult standard can u find for that? I have 311s and get 11mpg if i baby it. These trucks are square. To make it efficent is nearky impossible. Yes a 700r4 is the smartest thing. But forsomeone without a welder or oxysed torch installing a non factory transmisson is not is not cost effictive. If he.puts any taller gears in there all power is gone. Infact worse gpm is possibke due to more struggle to start after a stop. Sense the truck us a stock 6 shes got gears. To slam taller in there will indeed worsen the milage unless the car sees 75% highway. Cost effictive.
Posted via Mobile Device sorry for the spelling. On phone.
Old 09-11-2011, 11:48 PM   #9
67_SS396
If he has a grand to spend on a parts truck, he can pick up a rebuilt 700 and be on his way. Not sure where the rebuilt standard comes into play, but ok. Proper tuning and the right total package, decent mileage can be obtained fairly easily. If he has access to a salvage yard, he doesn't need a torch or welder to swap in a 700. That's pretty much a "bolt in" swap, as much as I hate that term.
RevLimit Offroad
Old 09-11-2011, 07:10 AM   #10
cr34t3d_by_d4rkd3n
Old 09-11-2011, 09:18 AM   #11
russgt
russgt's Avatar
How heavy is the boat that you pull? Do you have to really slip the clutch when pulling it out of the water? If it is heavy, I think that you would have problems if you just went to a highway gear and didnt swap to a transmission with a low first gear. Also, the great thing about our trucks is that there is plenty of room to swap in whatever you want and it is not that difficult.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 09-11-2011, 10:21 AM   #12
Breadman
Breadman's Avatar
The boat is just 2100 pounds (Bass Tracker 18.9 foot)
The carb. is a rodchester 2 barrel
mostly city driving
the only highway driving is to the lake
EVEN JESUS HAD A FISH STORY...JOHN 21: 6 and 11
Bass in picture is a 11.4 pound largemouth bass
I caught March 13 2014
Old 09-11-2011, 10:44 AM   #13
mooseknuckles
mooseknuckles's Avatar
swap in a 700r4...cheap, overdrive, low first gear, and other than driveshaft length, there shouldn't be any problems to installing it.
mooseknuckles is offline   Reply With Quote
Old 09-11-2011, 11:14 AM   #14
tucsonjwt
I would go with a higher gear rear end - 2.73 or 3.23 if you are concerned about towing. I would have someone experienced in differential work install it if you are not familiar with them. 700R4 would be next if you can afford it, but if it costs more than $500 to get it installed I would pass on it - city driving won't give you much benefit of overdrive on a 700R4.
tucsonjwt is offline   Reply With Quote
Old 09-11-2011, 01:12 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
You say it has low rear gears, but you don't sound as if you have confirmed what they are. Before you take anyone's advice on what to do, determine what ger ratio you actually have. If its 3.73 or lower, a gear swap to 3.42 or higher will get you about 1-2 MPG. If you can find a cheap axle with the gears you need, thats a pretty good trade up. If you have to buy new gears and possibly a 3 series carrier, then your not gaining much.
There is no doubt that swapping to a 4 or 5 speed stick would help. A 700r4 would be a good choice too if you prefer an auto. All of these would make your truck more efficient to drive and quieter as well. The cost might be a bit excessive for the gains in MPG so it's up to you to decide.
Check your gear ratio and tell us what you have.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-12-2011, 12:13 AM   #16
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
A daily driver would like a NV3500. OD and nice gearing for every day driving.
Welcome to the site.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
