air bag fittings
ok im just about ready to put all my suspension together but i still need fittings an airline. ihave 8 1/2 smc valves two viair 480c comp firestone bags 1/2" ports. bags are in but thats about it. anybody see anything else i may need except a air tank. any help would be appretiated this is the first time i have done air so not sure what all i need. also i have 4 three position toggle switches i was going to run to control everything
Frequent Flyer
Re: air bag fittings
Pressure switch
Fuse for power wire |
Gearhead
A drain fitting for the tank and an inline filter/water separator would be nice, I wish I had done those... I also wired a switch so I could manually turn off the compressor if the pressure switch fails or I need to shut down the compressor for any reason, i.e. drain the tank....
![]() Oh and gauges??
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 09-29-2011 at 09:39 AM. Reason: text |
needs more $$$
If you have 1/2 all the way through, you might want some type of flow control...I hear it's awfully fast.
1970 2wd Blazer |
#5 | |
Frequent Flyer
It was awful hard to adjust by just a few PSI at a time. |
Frequent Flyer
More good points... if you run a water trap before the tank you'll be amazed how much moisture you catch & yes a master power shut off to the air ride is nice too.
thanks any suggestions on where to get the best deal on air fittings for this
67-72 parts collector,…
![]() Join Date: Nov 2002
I know Fastenal carries "push-to-connect" brass fittings.
Just make sure you get DOT approved fittings,... and use some Loctite 545 Hydraulic thread sealer.
You will pay more, but do yourself a favor and buy name-brand fittings ... Parker or Swagelok preferably. You will thank yourself later when you are chasing leaks on the less expensive ones.
I purchased all of mine from my local Parker store but not sure if there is one located near you. |
needs more $$$
I too got mine at the local Parker store...a little spendy, but it was nice to be able to get them all minus shipping and right away.
1970 2wd Blazer |
