Rottenwood Garage Member
HELP...1986 C20 5.7....smog removed,,,Check engine light???
I dont have any experience with this crazy pre-87 emissions stuff. I dont have another one close by to compare it to.......We picked up this crew cab a few weeks ago.....running great. It looks like there may have been a smog pump at one time that was cut off??? A few tube things up top on each side and two plugs that go no where. It will throw a "check engine" light when on the highway. I am sure it has something to do with the unplugged stuff.
1) any pictures of what is should look like? 2)Will the plugs that arent hooked up effect this check engine light? 3)If so can they be jumped off? 4)Where do these pinched off tubes up top go to? 5) CHECK ENGINE LIGHT....are you kidding me...WHY? Whats it supposed to be telling me? Im sure I will eventually change the intake, carb and exhaust, but for now Id like to make sure its right. Thanks for your help!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 08-11-2010 at 03:53 PM. |
All About the BOWTIE
Re: HELP...1986 C20 5.7....smog removed,,,Check engine light???
Depending on your state, I don't know if you are required to take and emmisions test.. but if you don't... I would just unplug the bulb to the "check engine light",... most of these lights were hooked up to the emmisions system anyway (mine is)... seeings that yours was all hacked to peices (do you need it all back together?)... could be anything setting it off..... I have an 84 with all the smog stuff hooked up (strict smog laws here in Cali)... would show you pics.. but I'm pretty sure the plumbings different between 84's, and 86's..
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 08-11-2010 at 07:20 PM. |
#3 | |
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#4 | |
BTW.. Dude.. how big of a garage you got?? geez.. you got some rides LOL
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
Insert Witty Text Here
The C10 in 1986 didn't have a check engine light unless it was a California emissions model. Your C20 may be a CA emissions model.
Slonaker |
#6 | |
![]() If you have one this also means that you have ECM controlling carburetor. To determine what is causing SEL to be one - short pins A&B with a paper clip and turn ignition on, but do not start engine. SEL should blink code 12 3 times followed by the offending DTC. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Slots go on anything!
Just unplugging the smog will not set a CEL. You have something else going on. Pull the codes like RF said, and report back. I bet it is something else entirely.
1974 Jimmy- 5.3/4L80e/NP241 |
Thanks for the informative info!!! I will run out in a sec and look...HOWEVER last time I checked I DID NOT see a plug in under the dash. It was the first thing I looked for when that crazy check engine light came on. ill check to make sure it has not been unscrewed and tucked up in the dash.
There is NO OB port under the dash and NO electronic carb.
No port=no codes to repot. Lots of smog stuff, Check engine light and I cant remember if i mentioned it before....it also has a stupid CHOKE light that glows now and again. What was GM thinking?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 08-13-2010 at 04:43 PM. |
ehhh.. it was the 80's,... they were trying to be all "sophisticated" with the computer controlled stuff.. but bombed apparently.. I mean look at the early 80's Caddy's with the 4,6,8 HT electronically controlled engines that failed miserably.. Got a hand it to em for giving it a shot. They got better with time though....
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 08-13-2010 at 07:19 PM. |
Any other ideas why it would be throwing a check engine light?
If unplugged smog wont do it and it does not have a computer.....what throws the light?
If it doesnt have the electronic carb and the rest of the stuff associated with that. If you cant find a diagnostic port and theres no computer just take the bulb out of the dash so it doesnt light up anymore.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Thats what is going to happen but I am one of those "figure it out" types so the search goes on!
Theres probably nothing to figure out. If theres no computer and no sensors to read. The light is simply lit because it has power to it from somewhere. trace some wires under the dash. If the choke light acts up too there could just be a wiring issue behind the dash or cluster.
#15 | |
It will go back out when you shut the truck off and it will stay off untill you are back on the interstate. It never comes on driving around town.
#16 |
another possibilty could be the O2 Sensor... just a thought...
#17 |
I will look and see if I have them and report back. Any thoughts where they would be other than the exhaust? Thanks!
#18 |
Theres only going to be one and it should be near the exhaust manifold in the y pipe. You said you have no computer though. If thats true theres nothing for the o2 to send signal to.
#19 | |
My thoughts exactlt!
#20 |
The signal for the light should come directly from the computer. Like I said I think your chasing a ghost and theres a short or electrical problem in the dash itself.If theres for sure no computer then the light shouldnt be lit.
#21 |
.. I could be spit-ballin here... but if it had smog stuff,.. and a check engine light.. it has to have a brain(ECM) somewhere?...no? Did you check under the dash,.. behind the glove-box? I know that's where mine is located...
#22 |
78K & 79C Jimmys
now i'm curious........not up there?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#23 |
I cant tell what I am looking at......is that behind the glove box?
#24 |
![]() Join Date: Apr 2009
yes that is
#25 |
My 85 3/4 ton Suburban had the same emissions equipment, Dual smog pumps, No catalytic converters, No EST, No feedbak Quadrajet, Dual exhaust, Leaded gasoline compatible.
There is a "smog pump control module" on the firewall. Heres a pic of mine, The circle is where it used to be. It grounds the "check engine light" bulb when a fault is detected in the "Air Diverter solenoid" curcuit. Unplug the module, the light should go out. |
