Old 10-09-2011, 09:26 AM   #1
walls
cpp front sway bar w/ power steering?
I'll call cpp on Monday but for now, anyone ever have this combination?
I don't have a whole lot of clearance. I'm assuming when the suspension hits hard, it will hit the power steering. The factory type bar has a dip right after the front mounts, the cpp one, is flat. I didn't have a factory sway bar. I have 3" drop springs and shocks so suspension travel will be limited but this seems like it's pushing it. I don't have the bar mounted to the lower control arms yet. I'm going to wait to find out what I'm doing wrong or if I have the wrong bar for this application. Any thoughts. Hopefully you get an idea from these pictures.
walls is offline   Reply With Quote
Old 10-09-2011, 10:55 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: cpp front sway bar w/ power steering?
Did you bolt the sway bar directly against the frame? There should be some brackets that bolt on first then the sway bar gets bolted to those. All of my stuff came out of a 75 chevy truck but it is the same concept.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-09-2011, 11:10 AM   #3
walls
No, there's standoff type brackets similar to yours.
Like I said though, it doesn't have the bend in the bar like yours has. Maybe that's the missing detail.?
Old 10-09-2011, 01:31 PM   #4
Slow Build
Slow Build's Avatar
Where and how do you have the sway bar mounted to the lower control arm. It looks like it's connecting towards the back of the arm. Look at how John's sway bar is mounted above (on the front of the arm).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-09-2011, 01:48 PM   #5
walls
It's not mounted yet. It WOULD be mounted towards the front of the arm. I don't want to drill any holes yet, as I think something is not right.
It looks like it's going towards the back of the control arm because its just sitting on top. The cpp sway bar mounts by a single hole and a single bolt on each side.
Old 10-09-2011, 01:58 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
DPowers is offline   Reply With Quote
Old 10-09-2011, 02:21 PM   #7
Slow Build
Slow Build's Avatar
It looks like the original style PS takes up alot of space in that location. It would probably fit fine if you had the later style PS. You might have to use a different type of sway bar.
Past GM Trucks:
Old 10-09-2011, 04:05 PM   #8
walls
I think you're right. I'm going to call cpp tomorrow. I'll post what they say just for future reference.
Old 10-11-2011, 07:43 AM   #9
walls
They said, doesn't look like it will work.
I said, no kidding.
Oh well. At least they'll let me return it.
I guess I need to start a new thread. Factory PS + sway bar?
