Old 01-29-2023, 08:53 PM   #1
custom10nut
custom10nut's Avatar
Tilt Column, a couple more questions
Ok, so today I finally got around to taking the hub off my Tilt Column.
(In my defense, I had to fabricate the bolts to work with my pulle)
When I got the hub off I found three large Phillips Head screws. Are these what hold the turn signal mechanism in place?
AND
When I remove this Mechanism, will I be able to access the three bolts that have loosened in my tilt mechanism?
Another question I halve is about the Steering Wheel mount hub.
How far down onto the Steering Shaft should the hub go on?
How much of a gap should there be between the cancelling cam, and the Turn signal mechanism?
I hope someone can give me some insight on these questions.
custom10nut is offline   Reply With Quote
Old 02-01-2023, 01:54 PM   #2
custom10nut
Re: Tilt Column, a couple more questions
No insight, huh?
Old 02-01-2023, 02:48 PM   #3
70shortfleet
70shortfleet's Avatar
The 3 phillips head screws just hold the turn signal/wiring harness in place, you will have to go deeper to get to the 4 bolts that hold it tight! Watch this video and it will give you an idea where the 4 bolts are that come loose over time.
https://www.youtube.com/watch?v=2V__3OZRQw0
70shortfleet is offline   Reply With Quote
Old 02-02-2023, 08:26 AM   #4
custom10nut
Thanks Shortfleet.
This is the kind of video I was looking for.
Old 02-06-2023, 12:12 PM   #5
randy.powell
Watching - may have to tackle this myself in the not too far distant future....
RP
randy.powell is offline   Reply With Quote
