Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-18-2011, 05:33 PM   #1
truckdude239
truckdude239's Avatar
2003 zr2 over heats when towing
our o3 ar2 with 4.3 over heats only when towing, New radiator water pump t-stat new intake gaskets, oil coolerlines, belt and tenisor, only over heats when towing, towing a 6x12 foot tailor rated for 3500 ounds
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-18-2011, 08:30 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 2003 zr2 over heats when towing
Add and external tranny oil cooler. Remember the tranny and engine lines go int the radiator too. Are you still running Dexcool? I upgraded the mechanical fan on my Jimmy. A 4.0 explorer fan does a better job of cooling. I like the upgrade. Even my A/C works better!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-18-2011, 08:58 PM   #3
truckdude239
green stuff new fan clutch its my room mates truck and doesn't want to add a bigger cooler i told him that before but he maintains that it use not to over heat pulling so it shouldn't now, i think that the gm radiator design in those trucks are stupid, engine oil trans and coolant cooled in one. basic i think the trans is getting 2 hot for the radiator to cool, and shor tof a bigger cooler on the front its not going to get better
David fuller
2000 Tahoe 5.3l 378
Old 10-19-2011, 12:03 AM   #4
gchemist
gchemist's Avatar
There is an larger aftermarket radiator available. If he didn't replace the original radiator when Dexcool was removed, he probably has a partially clogged radiator.
Send him this link on upgrading to a V-8 Vette radiator.
http://www.jagsthatrun.com/Pages/Par...-Radiator.html
Old 10-19-2011, 08:16 PM   #5
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Are you towing on O/D?
ProStreet68SB is offline   Reply With Quote
Old 10-20-2011, 07:26 AM   #6
truckdude239
nope no o/d
David fuller
2000 Tahoe 5.3l 378
Old 10-20-2011, 02:20 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
what is the cam retard offset at? (think dist. timing)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-20-2011, 06:46 PM   #8
bighaas79
Factory or aftermarket radiator. There are alot of cheap aftermarket radiators out that don't flow like the factory ones did. There are aftermarket radiators that work fine but I say you got a radiator that just isn't cutting it. Everybody likes to save a buck but most of the time if you get too cheap it ends up costing you more in the long run.
bighaas79 is offline   Reply With Quote
