Old 10-22-2011, 09:05 AM   #1
summerj
Need Tire Advice for 700R 4 and 307 Gears
Hello All
I am finishing up the transmission install in my 65 short bed fleetside. Had a 700R 4 Built with 3rd and 4th gear ceramic clutch upgrade. Also stalled a 5 lug '72 rearend with 307 gears. An early 80's 350 CI chevy with headers mild cam and 750 Holley is my power plant. I will be pulling a 2200 lb catering trailer around town (with electric brakes) but not at hwy speeds. Trailer tung has about 250lbs of tung weight (frame Hitch installed)
Question: What size tires should I run with this gear/motor/ transmission combination? I want the stance of the truck to be semi low -so low profiles would be preferred. Also have the 2" drop spindles on front. Rims are 16"
Any Tire Size or Manufacturer Recommendations? Gotta purchase tires soon.
summerj is offline   Reply With Quote
