Old 10-21-2011, 11:45 AM   #1
TRAU 82
TRAU 82's Avatar
does a square peg fit into a round hole?
hows it going guys...sure i'm not the first one to ask and prob wont be the last, but got a question hoping you guys can shed some light. is there any good/better way to repair any of the square holes in the bed of our trucks for the carriage head bolts that may have gotten rounded out when removing the bed for the first time? tried like hell to keep it from happening, but when 2 or 3 started rounding out and spinning in place, i broke out the grinder and had to grind off every head!! any advice you guys can offer will be much appreciated...
TRAU 82 is offline   Reply With Quote
Old 10-21-2011, 11:50 AM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: does a square peg fit into a round hole?
Cut a little out of the weakened / rounded metal and weld in some new, stronger metal? That would be my guess... but I'm pretty handy with a welder and sheet metal working tools, so something like that would be easy for me. Depends on your personal skill level and comfort with doing a job like that.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 10-21-2011, 02:23 PM   #3
ont_guy_38
ont_guy_38's Avatar
Actually when putting new bolts in they will tighten good with the rounded out hole or excuse my language but some of the older fords trucks in the 80's had box bolts with a torx head on them
ont_guy_38 is offline   Reply With Quote
Old 10-21-2011, 03:06 PM   #4
TRAU 82
TRAU 82's Avatar
the availability of tools to do a job like that might prove to be an issue but as far as tackling the task at hand i wouldnt mind...would just try and suck up the new ones as much as possible first before i went through all the work. just didnt know if any of you guys had an easier fix to the problem. any other suggestions..?
Old 10-21-2011, 04:27 PM   #5
Prong
http://www.classicparts.com/1973-87-...ctinfo/08-912/
These and a welder will fix you up. That's what I did to mine. And after bedlining the bed, they're hardly noticeable.
Prong is offline   Reply With Quote
Old 10-21-2011, 07:55 PM   #6
Goldfinger
Goldfinger's Avatar
I've had a friend take some washers slightly smaller than the carriage bolt head and stamp the square into them at a machine shop. then weld them in and grind them smooth.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-21-2011, 11:02 PM   #7
russgt
russgt's Avatar
You could tack weld the head of the bolt to the floor to keep it from spinning.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-22-2011, 02:18 PM   #8
liftlawssuck
liftlawssuck's Avatar
I just put regular bolts back in. Forget about the carriage bolts. That way the next time they come right out. Lay a nice GM bed mat down and one will never know. As for getting the carriage bolts out. I always weld a nut to top of the bolt and put a wrench on it. I realize that you already got them out but maybe it will help next time.
liftlawssuck is offline   Reply With Quote
Old 10-24-2011, 11:29 AM   #9
TRAU 82
TRAU 82's Avatar
appreciate the advice fellas!
